Exhaust valve control - the opposite way | FerrariChat
Discussion in '458 Italia/488/F8' started by Don Molina, Jan 14, 2022.
  1. Don Molina
    Don Molina Rookie
    May 18, 2015
    14
    Hi everyone,
    I understand that everyone wants their Ferrari to be louder, and I see the valve control modules that are opening up the exhaust at all times to stir emotions.
    I actually don't think the 488 needs one, the way the valves are controlled by default is pretty nicely thought out on all modes.
    There is only one gripe I have. The exhaust opening above 3k RPM is great for general sporty driving, but I wish it could be deactivated somehow for cruising. At 150kph (around 90mph) in 7th gear, the engine is at around 3k RPM so if I want to cruise above that speed, I have to do it with the exhaust open. If you want to do a long trip in jurisdictions that allow the speed (Germany) or it is generally acceptable and with the flow of traffic (Italy, Greece) this can be a bit annoying.
    I understand I am 100% nitpicking here, but does anyone know of a way to override that behaviour? My car has a Capristo valve controller that the previous owner installed, and it works great switching between default and open all the time. Is there any way it can be programmed to be also closed all the time? Besides peace and quiet stealth also has its benefits some times :) Maybe other controllers can do that?
    The sales guy at the dealer I got it from actually had told me that the controller switches between always closed and always open, and if I want to go to default I have to turn the car off and on again - but that has not been my experience. So I'm either doing something wrong or he gave me some wrong info.
    TIA for any pointers :)
  2. PMiranda
    PMiranda Formula Junior
    Jul 23, 2004
    635
    Austin, TX
    Mine has 3 settings: always open, always closed, and variable(factory) behavior. You might be able to just get a 4 button remote for your controller
  3. Sargepug
    Sargepug Formula Junior
    Mar 23, 2020
    888
    NYC
    3? How is yours programmed? I can't recall mine off hand, but I think #1 is factory and #2 is always open, never tried #3 and #4 actually. What I did notice as of late, is that it's not opening at all anymore. I wonder if it's simply a weak battery, cause I do get the blue led flash, but no more action.
    What type of battery does it take, it's a very small odd cylindrical one...
  4. Sargepug
    Mar 23, 2020
    888
    NYC
    I hear ya, on long trips to events, etc (especially on the morning to), I keep her in sport, which only triggers the valves if you lay into it.
  5. PMiranda
    Jul 23, 2004
    635
    Austin, TX
    My remote has 4 buttons. I think A is always-open, B is always-closed. C and D are the same thing: factory behavior. I might have them mixed up since I have no paperwork so I usually just try them until it seems to be doing what I want :)
  6. Sargepug
    Mar 23, 2020
    888
    NYC
    Anybody have theirs handy to check the battery size?
  7. FFan5
    FFan5 Formula Junior
    Jul 7, 2018
    550
    The Capristo doesn't allow force closing the valves. I changed from Capristo to Forza in order to be able to do that. (My mechanic let me know that I could do some harm to the engine if I force close the valves and then drive the car aggressively. Perhaps that why Capristo doesn't support that behavior)
  8. Lagunae92
    Lagunae92 F1 Rookie
    2,724
    SoCal
    C and D are used to program which setting you want at startup. Valves open or factory.
  9. todd cloud
    todd cloud Formula 3
    Jun 21, 2019
    1,063
    Todd
    The Capristo will open closed valves, but will not close open valves.
    Safer.
  10. Phillychoi
    Phillychoi Karting
    187
    Lansdale, PA
    My Forza controller has only 2 buttons(A for factory setting B for always open) for my Pista. Is it different from the 488GTB?
  11. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,292
    Tampa FL
    My 488 valves are open all the time. The car is not loud, it just has a better sound below 3k rpm. With the valves open the car is no where near sounding loud and there is zero drone in the cabin.
    Napoli and MANDALAY like this.
  12. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    Having it closed for long periods of highway driving above 3k rpm is not healthy for the engine, you want the valves to be open.
  13. up4speed
    up4speed F1 Rookie
    3,649
    Long Island, NY
    Chris
    As others said, the Capristo doesn't have the ability to permanently close the valves, but the Forza controller does. Also, as others said, It's a bad idea to leave them closed. It has more back pressure with them closed. Back pressure is good for taking off from a stop (it helps with torque), however when running at higher RPM's, it will build up heat, and probably damage the engine/valves over time.
  14. Depreciating Asset
    Depreciating Asset Formula Junior
    Sep 1, 2019
    299
    Cary, NC
    Randy
    The Forza has the three modes mentioned above (always open, always closed, factory computer controlled.) The remotes have 4 buttons, but only because Forza uses generic off-the-shelf remotes that happen to have 4 buttons (you can find them on Amazon). A Forza controller set to always closed will do what you're asking for.
  15. Don Molina
    Don Molina Rookie
    May 18, 2015
    14
    Thanks for the insight guys, that's useful and interesting all around. I don't think I'm convinced that closed valves would hurt the engine with cruising speeds of 100-120mph. The car is barely under any significant load, regardless of the RPM due to the gearing. In any case, not a big issue, and since the Capristo doesn't allow the functionality, I'd rather spend the money on gas and tires than swapping it out for something that does.
    In any case, it's not that it's annoying or too loud. It's more about being a little stealthier on the highway and maybe making long drives a little easier. On the other hand, this is a good motivator to keep me under 140kph and easily avoid tickets :D
  16. PMiranda
    Jul 23, 2004
    635
    Austin, TX
    I've done a few hours at a time and what stood out to me was not exhaust sound (in sport), but the poor stereo quality (I think I need to install some forward tweeters to get some kind of imaging) and the lack of cruise control. Also the random people slowing down or speeding up to get a look at the car :)
  17. Don Molina
    Don Molina Rookie
    May 18, 2015
    14
    Between having the car for 3 months, COVID, and a toddler son, I haven't done a big trip yet in the car, but I think in traffic the cruise control's basic control scheme will be the most annoying part. I used to be able to do trips without touching the pedals for miles on end with other cars and conventional stalks or buttons on the steering wheel, but with my Quattroporte and now the 488 I have to fiddle between brake pedal and the rotary knobs. Minor grievances, but there nevertheless.
    Basic stereo is basic for sure, but when I saw first hand that the perfect spec doesn't exist when you're hunting second hand so you have to take what you can
  18. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Correct. Image Unavailable, Please Login
  19. Sargepug
    Mar 23, 2020
    888
    NYC
    Here's the Capristo info, which is the one I have. There is no way to shut the valves.....
