Exhaust valve controller really worth it | Page 4 | FerrariChat
Discussion in '458 Italia/488/F8' started by Randyslovis, Jan 21, 2017.
  1. Labman
    Labman F1 Rookie
    3,776
    Long Island, NY
    Steve
    #76 Labman, Apr 3, 2017
    Only during decel will it make a difference. The valves normally would close at a certain RPM but with the controller they won't do that.
  2. BlueIn2Red
    BlueIn2Red Karting
    Sep 29, 2006
    233
    Tring, UK
    Open valves make a huge difference in my opinion on a 458. I'm surprised to hear it's that different on a Speciale, but I've no experience there so can't comment (although I guess I just did!).
    (I use a Forza controller and am very happy with it - the ability to fully close the valves at all times is just as handy as having them always open.)
  3. deltona
    deltona Formula 3
    Aug 7, 2009
    1,386
    Justin
    Thanks for confirming this. I have ordered the Capristo controller this time for my F12 and look forward to using the memory function.
  4. DRPM
    DRPM Karting
    Mar 25, 2016
    151
    Montreal Quebec
    Where do you recommend installing the Capristo Controller in the 458 Italia.
    The cables provided have one long and one short so I can't run it to the side as shown with the Forza.
  5. Joe Rowett
    Joe Rowett Rookie
    Jan 27, 2018
    1
    Boise
    Joe Rowett
    Totally worth it in my new 488. Had the dealer install.
    LMH and Shadowfax like this.
  6. Jasflora
    Jasflora Karting
    Sep 30, 2018
    60
    Leeds United Kingdom
    Jas flora
    I had mine pinned open on 458 and after a while I started getting low rev partial misfire and although there was no CEL
    Diagnostic picked up fuel mid being too rich at exhaust. Had the valves set back to factory and misfire stopped though I don’t much like the mufflers on
    Will put either the capristo or Forza in the spring though undecided which
    A bit concerned about misfire returning
  7. Golattus
    Golattus Karting
    227
    JN
    Forza has a internal switch that programs the initial setup on every start up, you can choose to restart either open or closed.
  8. Viperjoe
    Viperjoe F1 Rookie
    Plugged the bypass valves on both my 458 and 488. Never had an issue and sound is great.
    Melvok, LMH, PJxxx and 1 other person like this.
  9. Cigarzman
    Cigarzman F1 Veteran
    + 1. What he said.
    Melvok likes this.
  10. MANDALAY
    MANDALAY F1 World Champ
    Owner Rossa Subscribed Silver Subscribed
    May 23, 2013
    11,077
    AUSTRALIA
    ANGELO
    Plugged mine by the dealer and no issue just beautiful sound :)
    Melvok likes this.
  11. tekaefixe
    tekaefixe Formula 3
    May 10, 2012
    1,201
    CH
    Paulo
    My Novitec rosso valve kicksass! Can’t recommend enough.
  12. docf
    docf Formula 3
    Sep 14, 2008
    1,356
    Florida
    Gary
    Thanks for the info as I recently had the dealer install the Capristo Controller in my 458. Had no idea that you could set the startup this way, nor did the dealer. Your unit has improved the joy of ownership of the 458. Thanks for the info.
  13. bisel
    bisel Formula 3
    1,138
    Scottsdale, Arizona
    Steve Bisel
    Been seeing some postings asking about the memory function with the controllers.
    Capristo has a feature where you can set the valve position at engine start using a memory feature on the remote. You can set the controller to set the bypass valves for open or ECU control.
    The Forza controller also has the feature allowing you to set the valve position for either of these two settings at engine start ... i.e., open or ECU control.
    Regards,
    Steve
  14. Golattus
    Golattus Karting
    227
    JN
    Today I tried for the first time the forza valve controller. Amazing sound!
    LMH likes this.
  15. Thecadster
    Thecadster F1 Veteran
    6,719
    Amazing info in this thread. I have had the Capristo controller in my F12 since the beginning, but I had no idea that it had a programming feature. I will have to set it up in the spring when I thaw out...lol.
  16. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,110
    Mel
  17. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,645
    Silicon Valley
    At least for awhile. I tried keeping my switch to “open” to simulate what it would be like if I had just plugged the lines instead. It sounds great at first, but gets tiring for longer drives. Having the ability to switch it at will is totally worth it.
    Viperjoe and Shadowfax like this.
  18. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    I found the same. The value of having switching options really should not be underestimated if you drive your car over any sort of distance or length of time.
    docf and Need4Spd like this.
  19. Golattus
    Golattus Karting
    227
    JN
    I have controller fitted but I ran them opened since minute one.
    It’s addictive, also for my neighbors
  20. LMH
    LMH Karting
    May 5, 2019
    195
    Spain
    Dear all, after those years, are you still happy with your valve controllers?, any issues?
    just bought an Speciale recently and this post has been an inspiration, about to order one valve controller
    thanks
  21. Lagunae92
    Lagunae92 Formula 3
    2,041
    SoCal
    I enjoyed it on the 458. Going to get one for the 812 now. Looking into one for the Pista when it comes. Seems to be more complicated. Doesn’t hurt anything and is a relatively nominal expense.
    LMH likes this.
  22. Rdwaggie
    Rdwaggie Karting
    106
    Absolutely
    LMH likes this.
  23. Adamtensta
    Adamtensta Karting
    Jan 9, 2019
    217
    Scandinavia
    Adam Tensta
    My 458 has one from capristo and was ther when I bought the car. It's amazing!
    Congrats on your speciale
    Sent from my LYA-L29 using Tapatalk
    LMH likes this.
  24. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    I've had two of Forzas controllers now - one on my 488gtb and now one on my Pista. Both work flawlessly and quite frankly I wouldn't own one of these cars without a valve controller now. Just so much better having options.
    LMH and Melvok like this.
  25. cole328
    cole328 Formula Junior
    May 9, 2014
    882
    I have one on my 430 Capristo. Love it. It’s “open” 99.9% of the time
    LMH likes this.
