Exhaust valve guides leaking. | FerrariChat
Discussion in '348/355' started by gandalfthegray., Dec 11, 2007.
  1. gandalfthegray.
    gandalfthegray. Formula Junior
    Jul 18, 2006
    692
    Pinewood, MN
    Steve
    My 348 goes in for the major service next week. When the original PPI was performed it found leaking exhaust valve guides. During the major, we will be pulling the heads to fix the guide issue.
    Is there an aftermarket upgrade to the Ferrari guides? It seems as though guide failure is quite common throughout the models. I don't want to have to do this again anytime soon.
  2. 348SStb
    348SStb F1 Rookie
    Hi there,
    Please fill out your profile with your name and location so we all know who you are, even though some of us have seen your posts.
    I would like to offer a correction by saying that guide failure is not common throughout the Ferrari models. It does have a tendency to occur on the 355, but it is not "common" on the 355.
    The 348 is NOT known to have valve guide issues. Something else is causing, or did cause, the problem. You should be fine with the stock guides so long as the other problem is addressed.
    Please tell us about the car. Leakdown results? Compression results? Mileage?
  3. gandalfthegray.
    Jul 18, 2006
    692
    Pinewood, MN
    Steve
    Oops! I guess I never did anything with the profile. A real quick run down, I'm Steve, live in northern Minnesota and have recently acquired my first Ferrari. A 90 348ts. Rosso Corsa over tan with 42K on the clock. Bone stock.
    As far as the PPI showed, compression was good across the board with numbers reading between 180 and 190. There was actually three cylinders in question with the leak down. #3, 5 and 6. They were 18%, 22% and 24%. The others checked out ok. The leak down was performed by two different shops, and both found similar results. Both shops confirmed that the leak was on the exhaust side. I can offer no explanation in what caused the leaking valves.
    I have a very limited knowledge of these cars, but am learning from the forum. I suppose its not fair to say the guide failure is "common", as this is the only Ferrari I have ever owned. It does seem however, that someone is mentioning it in one way or another in regards to a 355/348 PPI or major quite often. I just assumed that it was routine with these cars.
    So far I have been able to put 177 miles on the car, and enjoy it more every time I step into it. My older brother is a Viper owner and spends most of his time mocking my new purchase and poking fun of the lack of performance, outrageous maintenance costs and what seems to every magazine and collector car guide to be considered the dull Ferrari. :(
    I am looking forward to a fresh service and to be able to put some miles on the car in the spring. I must admit that I had wanted to buy a 355, but my banker was able to give roughly twenty five thousand good reasons that was not going to happen at this time. So thats a quick run down that brings us to where I am now.
    Steve
  4. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    Hi Steve. I had the same issue, bad leakdown due to worn valve guides on a 348. My shop told me the original material used was prone to this failure and the valve guides were replaced with a new material, but I don't know exactly which. If you want you can PM me and I can send you the contact information for the shop in question so you can call them to ask.
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Your leak down test will identify leaks, but not necessarily the source (you listen to hear where the compressed air escapes). You could get bad leakdown numbers from bent/worn valve guides, valves that aren't seating properly, burned valves, burned/worn rings, etc.
    Are you burning oil (lots of smoke)? When I bent my 16 exhaust valve guides (you can bend valve guides and you can bend actual valves - different beasts, though!) with a jammed cam pulley my engine would run, but pour smoke everywhere...and it consumed copious amounts of oil.
    If I read right you said that you had good compression, but a poor leakdown on 3 cylinders, yes?
    Have you looked into your oil reservoir with a flashlight to see if the oil there looks milky white? Have you looked into your coolant reservoir to see if there is a rainbow film on top?
    Anyway, it's unusual to get a good compression test on a cylinder with a bad leakdown number.
    Before replacing parts, I'd suggest having someone else perform new compression and leakdown tests (with you there) on all cylinders, and then perform a wet compression test on cylinders #3, 5, and 6 per your leakdown numbers. That data would go a long way toward telling you what's up (with the engine still in the car).
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    You want to first run the engine to get it hot because metal/objects expand (only accurate way for a leakdown) and initally put no additives in the cylinders to alter the leakdown test (does your Ferrari normally run with a tablespoon of oil in the cylinders?).
    With engine off, next take out all spark plugs for the test. Remove your oil cap, coolant cap, and crack open your throttle.
    At Top Dead Center (TDC), apply compressed air pressure via a differential pressure tester through a spark plug hole and note the reading. You should be maintaining somewhere in the area of 90% of what you put in for a nice "tight" cylinder. More importantly, all cylinders should be within 5% of each other.
    When rotating a cylinder to TDC, don't go past TDC and then back. That might appear to "fix" what would otherwise show to be a leaking cylinder.
    If you have excessive leakage, use your ears to locate the cause. That compressed air has to go somewhere!
    Pop the oil cap off and listen for a hiss (blowby from rings or worse), pop off the coolant cap and look for bubbles (headgasket or block problem), listen at the exhaust pipe (exhaust valves/seating/guides), and finally listen to the intake with the throttle cracked/butterfly open (intake valves). This will help isolate your problem and direct you to the proper corrective action.
    That's why it's important for you to be there when the leakdown test is performed!
    FYI: most leakdown testers have two gauges, a pressure regulator, manifold, & hose. One gauge shows the pressure being applied, and the other shows how much pressure the cylinder is holding. The difference between the two gauges is your leakdown. So if you have 100 psi on the first and 80 psi on the 2nd gauge, then you have 20% leakdown on that cylinder.
  7. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    I have heard that it can be as simple as carbon build up from lack of use (or use that really gets the motor up to temperature). So would also suggest you follow the above directions before spending chunks of money.
  8. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    Interesting. My car definitely suffered from these symptons, the carbon build up was pretty bad.
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Yup. Carbon accumulating on the valve and/or on the valve seat will prevent a valve from fully sealing...which lets some gasses escape (hence, a low compression # and a high leakdown number).
    Hey, it's why I use Techron every other gas tank!
  10. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    I am not pretending to be an expert, but I believe that Tom J. at Sport Auto reported seeing more than one 355 fail leakdown/compression purely due to carbon from lack of use. How many cars do you think have received new valve guides that maybe didn't need it? Let's face it, poor LD/C on a 355 and the knee jerk is the big dollar fix.
    When I owned my 355 ( <sniff> :( ) I made a point every time I started it to drive it until it was warm and then give it several full throttle runs through the entire rev range over varied driving. It was a minimum 30 minute ritual, even if I just wanted to pull it out of the garage and wash it! ("Honey, I'll be back in an hour... I need to wash the car... ;) )
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    ...most of the ones that had a bad leakdown test but that mysteriously *weren't* burning oil, I'd guess.
  12. Ricambi America
    Sponsor Owner
    But that particular F355, which I know too, actually did run hard lots of times.
    (Not hard enough to keep pace with Eddie and me however. ;) )
  13. gandalfthegray.
    Jul 18, 2006
    692
    Pinewood, MN
    Steve
    In my case, the 348 is in a shop in southern Cal. I live in Minnesota.
    The owner of the shop told the same story of how many times the valves just have carbon build up and that it would need run time. In total the car has seen over 300 miles since purchase (first PPI leak down) and has shown no improvement. The major is well over due (7 yrs since last belt) so it needs to be done immediately. One can hope that with more miles the leak down may clear up, but at this time, the engine is already out. It should happen now. Once the car goes back to Minnesota, I have no mechanic or reputable shop (yet) to service the car. At this point in time, the decision to pull the heads during the major is decided. I can't take the chance of the problem clearing up over time.
    So that is where I was wondering about any upgrades to existing guides.
  14. 348SStb
    348SStb F1 Rookie
    Well, the F355 did use the same guides as the 348; and then in middle 1998, Ferrari switched to steel-sintered guides.
    Maybe the upgraded F355 guides will work on the 348? I don't know. Let's hear from someone who can give us the answer.
    Also, you should consider upgrading your timing belt tensioner bearing. Daniel at Ricambi sells the Hill Engineering tensioner bearing, which is a much stronger and better bearing than the Ferrari part. I have used it for my car.
  15. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Nope. Different alloys and different sizes and different shapes in those valve guides.
  16. 348SStb
    348SStb F1 Rookie
    Am I correct to say that the 355 at first used the same guides as the 348?
  17. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    No. Let me see if I can find a picture of them...
  18. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #18 No Doubt, Dec 12, 2007
  19. hacker-pschorr
    hacker-pschorr Formula Junior
    Sep 27, 2006
    584
    Land of Lambeau
    I agree – I’m new to the Ferrari world, I am no stranger to valve guide issues.
    Porsche's (at least 928's, 944's, and air cooled 911's) have valve guides that I have seen worn out by 50,000 miles. I never saw a Porsche with bad valve guides that did not also show signs of oil in the cylinder.
    With all of my cars I check the spark plugs a few times over the driving season to keep an eye on these issues. I’m hoping that pulling a spark plug or two on my fathers recently purchased 355 isn’t very difficult since I plan to do the same with his car. Better safe then sorry.
