430 - Exhaust valve rattle/buzz - possibly | FerrariChat
430 Exhaust valve rattle/buzz - possibly
Discussion in '360/430' started by Spleen, Jun 16, 2021.
  1. Spleen
    Spleen Karting
    Mar 2, 2021
    53
    UK, West Berkshire
    Spleen
    Annoying buzz/rattle from the engine bay which is driving me bloody nuts. So far I've had the following done:
    • Loose exhaust tip sorted
    • LH manifold heat shield tac welded as slightly loose
    • Exhaust brackets checked - all good
    • Stripped bolt in exhaust bracket replaced
    • Twin pipe brackets tightened
    • Engine bay panels taken out and car driven, noise still present
    • Spring attached to exhaust valve for added tension - no joy
    Noise occurs at 3-3100k, warm or cold. If in sport or race and you accelerate hard from 3k the buzz just overshadows everything and it sounds like it occurs when the valves open. Below 3k nothing. Going out for spirited hoon is just frustrating because all I can hear is the noise, it's just not a clean sound.
    It's going back to GTO Engineering tomorrow for another look but just wondered if the wise and wonderful of Ferrarichat have any other ideas because I'm all out. The other question I have is can valves be economically replaced or fixed/serviced?
    Sigh.
  2. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,623
    San Jose
    dc
    Shafts of the valves could be worn and then heat+resonance of the exhaust pressure causes to exacerbate?
    My suggestion would be to borrow a gopro and then record the event with different areas under surveillance.
    Spleen and NMNMNMN like this.
  3. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,005
    Cape Town South Afri
    Dave
    Inlet manifold throttle butterflies , for the variable inlet track length ? Just a suggestion
    Spleen likes this.
  4. AandSC
    AandSC Formula Junior Silver Subscribed
    Dec 12, 2016
    958
    Jax, FL
    Allen
    Taillights rubbing against the body??
    NMNMNMN likes this.
  5. Spleen
    Spleen Karting
    Mar 2, 2021
    53
    UK, West Berkshire
    Spleen
    Cheers all, what I'd really like to do is find another F430 Spider and compare them side by side. My money's on knackered valves but I have no idea if they can be serviced or replaced, looking on Eurospares it seems as if they are part of the whole tailpipe assembly. Chatting with the tech yesterday (I took him out for a drive and he can definitely hear something, he's just not sure what it is) and the plan is to dismantle the valves as far as he can to see if that removes the problem. If so then at least we know where we are.
    It's crap really because this noise is really spoiling it for me, I can't unhear it and to me it's just horrible. If it can't be solved I'm not sure I can live with it. :(
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,947
    Central NJ
    Dominick
    A quick test would be to wrap valve with something that is fire and melt proof and sound deadening ..and see for a very small trip if sound changes etc .. just don't know what to wrap with
    Spleen likes this.
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,947
    Central NJ
    Dominick
  8. redcaruser
    redcaruser Formula 3
    Apr 8, 2012
    2,426
    switzerland
    daniel
    Does it matter if the roof is open or closed?
  9. Spleen
    Spleen Karting
    Mar 2, 2021
    53
    UK, West Berkshire
    Spleen
    The sound is always there but is much more obvious when the roof is down and the windows are up.
  10. redcaruser
    Apr 8, 2012
    2,426
    switzerland
    daniel
    Then you can rule out the soft top mechanism as the source of the fault, so that's good.
    Then the next question would be, is the noise present even when stationary or only while driving?
  11. Spleen
    Spleen Karting
    Mar 2, 2021
    53
    UK, West Berkshire
    Spleen
    Only when driving.
  12. Kent Adams
    Kent Adams F1 Rookie Silver Subscribed
    Sep 11, 2020
    3,292
    cracked manifold. Do you still have the factory headers on the car?
  13. Spleen
    Spleen Karting
    Mar 2, 2021
    53
    UK, West Berkshire
    Spleen
    Passed the smoke test a couple of weeks ago so they’re fine.
  14. Scottslaw
    Scottslaw Formula Junior
    Jul 9, 2015
    602
    Instagram: Needmoregarage
    Try to disconnect the vacuum lines to the valves and see if that makes a difference. If it does, you will know you are on the right track to address the valves. I concur however that it looks like the shafts aren't really replaceable. You'd have to buy a new middle section. would probably be cheaper to buy an aftermarket exhaust!
  15. Spleen
    Spleen Karting
    Mar 2, 2021
    53
    UK, West Berkshire
    Spleen
    Aye, I don't think they're fixable things so it may well be that I have to replace the outer tailpipes. It's still with GTO so fingers crossed...
  16. Moopz
    Moopz F1 Veteran Owner Rossa Subscribed
    Jun 29, 2004
    5,555
    Orlando, FL
    My exhaust broke apart inside and rattled like yours. I had mine replaced with the OEM sport exhaust.
    Sent from my SM-N975U using Tapatalk
    one4torque likes this.
  17. ttforcefed
    ttforcefed F1 World Champ Rossa Subscribed
    Aug 22, 2002
    19,257
    is it a baseball card in spoke of a wheel but metallic type sound?
  18. one4torque
    one4torque F1 Veteran Silver Subscribed
    May 20, 2018
    5,725
    Houston
    One4torque
    Moopz— was thinking same thing… a baffle break loose inside the muffler can.
    Moopz likes this.
  19. Spleen
    Spleen Karting
    Mar 2, 2021
    53
    UK, West Berkshire
    Spleen
    Hmm, interesting. Not sure it does, if you recorded it and slowed it down maybe but thinking back to when I was a nipper and doing the playing card trick on my bike then no. Not heard from GTO since dropping the car off last week, will try and get an update today.
  20. Spleen
    Spleen Karting
    Mar 2, 2021
    53
    UK, West Berkshire
    Spleen
    So the verdict is - it's normal. I've had two different orgs look at it and beyond the most obvious problems listed above that have been fixed there doesn't appear to be anything else amiss. GTO did says that it sounds like a normal 430 and they can be a bit 'raspy' when pressing on and is not unusual on other, more newer models.
    It's my first Ferrari and I thought I would have a cleaner sound but if the noise I'm hearing is normal then I'll just have to live with it and readjust my ears. Tiny bit disappointed if I'm honest but hey-ho, at least there's nothing I have to shell out £££s on to fix!
  21. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,045
    My F355 had an exhaust rattle/buzz...it was the muffler box had a broken or cracked baffle inside. Capristo replacement muffler resolved it.
  22. Moopz
    Jun 29, 2004
    5,555
    Orlando, FL
    Please post a video. I'm curious because I don't have any rattles normally.
  23. Spleen
    Spleen Karting
    Mar 2, 2021
    53
    UK, West Berkshire
    Spleen
    I don’t really have the gear to film it, I’m going to pick the car up tomorrow and have a chat with the workshop manager, see what she says.
  24. craze
    craze Formula 3
    Mar 5, 2021
    1,165
    Melbourne
    Michael
    mine has a slight buzz noise at certain rpm like something is vibrating, cant find it!
  25. Spleen
    Spleen Karting
    Mar 2, 2021
    53
    UK, West Berkshire
    Spleen
    What RPM?
