Exhaust valve stock open. | FerrariChat
Discussion in 'Technical Q&A' started by hazimaw, Oct 7, 2016.
  1. hazimaw
    hazimaw Rookie
    Aug 21, 2015
    39
    Hello,
    My left side exhaust valve is always open. (Vac. Hoses are connected to both valves )
    So I decided to unplug both sides to have an equal pressure.... but it's a bit loud on highway speed. And the car needs some back pressure for smother cruising..
    Where can I buy just the valve, or is it fixable?
    Ferrari want about 3k for a complete exhaust pipe with the valve.
    It's for 09 f430
    Thank you for your help.
    Sent from my HTC One_M8 dual sim using Tapatalk
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    Take a look thro the 430 section for similar previous - you should also find other suggestions such as fitting the Capristo type switchable exhaust valves
  3. hazimaw
    hazimaw Rookie
    Aug 21, 2015
    39
    I did look in f430 section, but no luck.
    I'll be installing v. Switch, but first I need to fix the open valve thing.
  4. bisel
    bisel Formula 3
    1,138
    Scottsdale, Arizona
    Steve Bisel
    I am not entirely certain, but I would think one could cut out the existing valve and weld in a new one.
    Steve
  5. hazimaw
    hazimaw Rookie
    Aug 21, 2015
    39
    This is my plan, but from where can I buy it?
  6. bisel
    bisel Formula 3
    1,138
    Scottsdale, Arizona
    Steve Bisel
    This is the sort of part you will likely to pick up from a salvage company.
    I get a lot of my used parts at GT Auto Parts in Phoenix. They have new as well, but they do recycle as well.
    G.T. Car Parts INC
    One place in LA area that I have used is Exotic Auto Recycling ...
    Regards,
    Steve
  7. hazimaw
    hazimaw Rookie
    Aug 21, 2015
    39
    Thanks a lot Steve.
    Regards,
    Hazim
