Expansion Tank for 328 . Any for less than $415? | FerrariChat
Discussion in 'Technical Q&A' started by drjohngober, Mar 27, 2007.
  1. drjohngober
    drjohngober Formula 3
    Jul 23, 2006
    2,040
    Cville and Gbury Tex
    Dr.John Gober
    My 1986 328 GTS has been running perfectly without any heating issues. While getting the clutch cable replaced, mechanic notieced a little leak around expansion tank, pressure test confirmed.
    I have searched F Chat and cannot find any for less than $400. Considering having one fabricated for less than $100. Any recommendations?
  2. BigTex
    79,398
    Houston, Texas
    Bubba
    Man, it's just a steel tank can the one you have be repaired at a radiator shop?
    Down in Australia section there is a repro in stainless, is that the one you've found?
    Try TRutlands or Ricambi America??
  3. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,066
    Kansas
    Sean F
    No kidding, just repair and repaint. No need to replace.
  4. f355spider
    f355spider F1 World Champ
    18,053
    I would only recommend that you keep the car as original as possible for resale value. So replace with oem or repair your exisiting one. Unless your fabricator can make one that looks original.
  5. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,607
    Gates Mills, Ohio
    Jon
    I bought one and am having mine replaced in the next couple of weeks. They're powdercoated steel, to handle the heat and pressure, and after 20 years, well... I asked my tech about refinishing, because the powdercoating had started to flake off. But the real issue isn't cosmetic.
    Look at the top of yours. If it is bowed out on top (i.e., bulging up), it's already starting to deform. Not repairable.
    $408. Pay to play, I guess. And I'd agree with Dave - a 328 should have a Ferrari expansion tank. I doubt you'd save much money now with a knock-off, and it would turn a lot of buyers off at resale time.
  6. drjohngober
    Jul 23, 2006
    2,040
    Dr.John Gober
    Probably true. $400 for a metal box. Even the guy at Rutlands was apologetic.
  7. marklintott
    marklintott Formula Junior
    585
    Taipei Taiwan / Somerset UK
    Mark Lintott
  8. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    Big Tex do you have the link or would you please direct me to the Aussie section w/ the stainless repro?..
