News
Expensive noise....
Discussion in 'Australia' started by Dave 456, Aug 14, 2009.
  1. Dave 456
    Dave 456 Formula 3
    Nov 15, 2007
    1,317
    Sydney, Australia
    Dave Simons
    OK, this isn't about an F-car, but kinda related.. Driving to work this morning in my (formerly)trusty Alfa GT 3.2 and.....bang, followed by a very colourful display of warning lights and messages.
    Cambelt failed at 61K and a few months out of warranty. The irony is that it was booked in for a cambelt change on Monday - Oh well, they will have a few other things to do as well as the cambelt now! Scored 50% on bent valves - 12 out of 24. Guess that when the book says 60K, they mean it.
  3. moretti
    moretti Four Time F1 World Champ
    Nov 1, 2003
    47,964
    Australia
    that's bad luck Dave, unusual for the Italians to be so correct
  4. Aircon
    Aircon Eight Time F1 World Champ
    Jun 23, 2003
    88,822
    Melbourne, Australia
    Peter
    ouch!!
    a cambelt like the fcar ones?
  5. SPEEDCORE
    SPEEDCORE Four Time F1 World Champ
    Jul 11, 2005
    42,494
    Toe Knee
  6. IanB
    IanB F1 World Champ
    Jun 15, 2006
    13,399
    but what did the valves do to the piston crowns?
  8. Arvin Grajau
    Arvin Grajau Five Time F1 World Champ
    Jun 7, 2006
    59,117
    Arvin Grajau
    #6 Arvin Grajau, Aug 14, 2009
  9. Dave 456
    Dave 456 Formula 3
    Nov 15, 2007
    1,317
    Sydney, Australia
    Dave Simons
    Almost, the V6 Alfa has one long belt, rather than 2 shorter belts like most belt drive Ferrari engines - this is cunningly designed, in the event of a belt failure, to take out the valves on both banks of cylinders.
  10. Dave 456
    Dave 456 Formula 3
    Nov 15, 2007
    1,317
    Sydney, Australia
    Dave Simons
    #8 Dave 456, Aug 14, 2009
    Some of the piston crowns have little smiley faces.......Apparently it is unusual to damage the pistons enough to require replacement - the valves are pretty small, with thin stems that bend easily. Different story if the valve head separates though.....Which I couldn't see evidence of, using a borescope.
    Yes, I know - real engines have chains or gears....
  11. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,189
    State of confusion
    a.n.other
    The Alfa forums are full of belt failures around the official replacement numbers.
    This is far from uncommon.
    Alfa belts seem to really be the way Ferraris are reputed to be.
    Doesn't make it any less unpleasant to have happen though.
  13. moretti
    Nov 1, 2003
    47,964
    Australia
    my brother use to do all the Alfa tuning in Sydney's west many years ago, swore that when the service time for the belt was due to DO IT !!
    he could do the belt change in under 20 minutes and that included checking the tension on the headbolts before doing the cambelt
  14. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,189
    State of confusion
    a.n.other
    Plenty of practice, eh?
    Seems they lost the plot after the 1750 and 2000GTV period.
    Tossed out all the things that were good. Gear change, timing chains etc.
  15. Looney
    Looney F1 Rookie
    Jul 1, 2004
    2,677
    Gold Coast
    BB
    mate i feel for ya, sorry to hear it
  16. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    While Alfa Romeo did loose the plot somewhat there is no denying that their v6 engine is a fncken awesome engine, one of the all time great driving engines.
    One day I'll only a v6 75 as a family car ... to go with my 1750GTV.
    Pete
  17. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,852
    Mount Isa, Australia
    Pap
    Sorry to hear Dave! :(:(
  18. Dave 456
    Dave 456 Formula 3
    Nov 15, 2007
    1,317
    Sydney, Australia
    Dave Simons
    #15 Dave 456, Aug 14, 2009
    Pete, indeed, the Busso V6 is a wonderful engine - one reason I bought the GT is that it was the "last of the line" Busso designed engine from the Arese factory. It sounds better than any other modern V6. Frankly, I'm a bit gun shy now - This in a car that has been very gently driven, never tracked, probably been over 5 grand on a handful of occasions.
    Oh well, company car, the company can pay for it. I did contact Ateco/Alfa, but they weren't interested, not that there would be any reason to expect them to.
    Thanks for the sympathy guys! This experience will certainly focus my attention on the 456 belts - changed a couple of weeks ago.
  19. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Gee, why be so gun shy?
    Just change the belts at say 40,000 maybe instead of 61,000 and all should be good. In the end the belt did what Alfa Romeo said it would ... make 60,000 km's.
    Note also a belt only change is cheap thing for these engines ... unlike Ferraris.
    Pete
  20. Dave 456
    Dave 456 Formula 3
    Nov 15, 2007
    1,317
    Sydney, Australia
    Dave Simons
    Gun shy of running 60k, per Alfa recommendation, on a Alfa V6 cambelt again! Changing cambelts on a DD at 40 k (obviously necessary in this case) is madness. Most sensible cars can run 100k with virtually no likelihood of failure.
    Not cheap in my book - $1500 from a dealer, $12-1300 from an independent - that's more than changing the belts (only) on a 456! I know, I just had it done - 10 hours labour + $350 in (OEM) parts.
    Modeler, I think, observed that cb failure at this distance is not uncommon - on checking around, he is absolutely correct - very common. My Alfa shop has done plenty - maybe 10 a year.
    Alfa need to do a reliability engineering exercise. Having run plenty for airlines - I'm pretty sure I know what the problem is. The 60k recommendation is way, way too close to the mean time between failures (MTBF) number, which is probably 70-80k. Depending on the level of risk associated with the failure, a reasonable service life would be 40k, as you suggest. The problem with that is that if a salesman pointed out that a prospective owner was going to have to stump up $1500 every 2 years in normal use, compared with a lot less( less than $500 for a 16v Citroen engine, at a dealer) every, say, 5-10 years, buyers would stay away in droves.
    What irritates me is that the 60k recommendation leaves no margin for normal servicing delays - I wasn't trying to stretch (pun intended) the belt for another 10k, it was booked in before 60k.
    The car was going in January anyway, a few things were starting to annoy me as a DD - lousy visibility, crap turning circle, Sydney roads are getting worse, so the ride and short suspension travel is getting tedious. Funnily enough, since going back to a C5 as a DD, the roads don't seem so bad after all! That said, I used the GT for a weekend in the southern highlands recently, open good roads, no supermarket parking - it was perfect.
    Don't get me wrong, I still love Alfas; I've had plenty and no doubt will have more - just helped my son buy a nice, 2 owner 60k 916 spider - with a fresh cambelt. However, if 40k safe life for a cambelt is typical - I'll check this on the Mito - I'll consider something else.
  21. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Don't buy a Ducati ... :)
    Anyway I don't understand why changing a belt on an Alfa v6 has become so expensive ... I've done one on a 75 and it was a piece of p!ss?. Although in your car the engine would be the wrong way around.
    My comment regarding changing sooner is because I maintain my own cars/bikes, thus we are only talking the cost of a belt ... as far as I am concern worth it, although my DD has a chain and is a Suzuki m/c.
    Pete
  22. Horse
    Horse Two Time F1 World Champ
    Dec 1, 2005
    27,393
    Brisvegas
    Jon
    Funny thing is that when the "new" Alfas came out, the belt change was advised at 100,000 km.
  23. Dave 456
    Dave 456 Formula 3
    Nov 15, 2007
    1,317
    Sydney, Australia
    Dave Simons
    #20 Dave 456, Aug 20, 2009
    Well, I had a couple of Dukes, many moons ago - apart from burning pistons in a 250 desmo, they were pretty good.
    Yep, the transverse V6 is a PITA to fiddle with, I think that's where the labour time goes, that and all the cr#p on modern engines. The $140/hr helps lighten the wallet a bit too.I try to avoid serious work on DD's, but do all the work(except panels) on race/toy cars. The cb change on the 456 was a "while your'e there" deal as the belts had to come off for another job that was cheaper to get a specialist for than make the tooling myself.Also, I wanted someone who knows the cars well to look it over. The 456 is pretty easy to work on, there is just more of stuff.
    As an aside, I don't think the 2 cam V6's have the same issue as the 4 cam engines. This might be because in the 12v engine each camshaft has 6 differently timed lobes, whereas the 24v engines camshafts have only 3 (pairs) of differently timed lobes. This would affect vibration frequencies.
    The problem with warranty cars is that you're stuck with the dealer and, from what I've experienced, always get bent over... with the honorable exception of a Citroen dealer that I've bought cars from for 20 years.
  24. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,189
    State of confusion
    a.n.other
    Then Alfa/Ateco copped a flood of warranty belt and top end jobs. The new number resulted.
    They really need the tensioner replaced along with the belts every time.
    IMHO its the tensioner that's at fault and true cause of the problem.
  25. Horse
    Dec 1, 2005
    27,393
    Brisvegas
    Jon
    There has got to be more to it, you know.
  26. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,189
    State of confusion
    a.n.other
    I think so. Maybe the extra sentence I added while you were posting could be a factor.
  27. Horse
    Dec 1, 2005
    27,393
    Brisvegas
    Jon
    Doesn't explain why they didn't last 3 years or 100,000 when new though.
  28. Dave 456
    Dave 456 Formula 3
    Nov 15, 2007
    1,317
    Sydney, Australia
    Dave Simons
    Well, I wonder why the current 2.2JTS and 3.2 V6 Alfa engines have - wait, wait for it, .........chain driven camshafts.......
