355 - Experiences with exhaust bypass valve controller by Forza Componenti | FerrariChat
355 Experiences with exhaust bypass valve controller by Forza Componenti
Discussion in '348/355' started by DamianoITA, Mar 20, 2024.
  1. DamianoITA
    DamianoITA Rookie
    Feb 22, 2024
    8
  2. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    I have fitted it to 3 cars including my own. Its probably the best controller on the market and is very easy to install.
  3. fboutlaw
    fboutlaw Formula Junior
    Dec 3, 2014
    260
    Woodside, CA
    I had used this on my F430 when I had one. Same comments as above. Very simple and does exacatly what it intends to do.
    The question you have is... why do I need this?
  4. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,256
    I have a valvetronic on my Evo. Easy to install and works perfectly.
  5. ShineKen
    ShineKen F1 World Champ
    19,870
    Southern California
    Nostradamus
    Interesting to see it being sold by a Fiat specialist.
  6. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,710
    Let's see:: $375 versus maybe $10 of wire, $10 switch, $1 resistor, $1 diode and a bit of stoogery* for the same effect. $22 versus $375 Hmmmmm
    (*) with no disrespect to self respecting stooges.
  7. DamianoITA
    DamianoITA Rookie
    Feb 22, 2024
    8
    Wiring the valve on a 5.2 can light up the engine warning light?
  8. DamianoITA
    DamianoITA Rookie
    Feb 22, 2024
    8
    To full hear the sound of my tubi exhaust :-D
  9. Qavion
    Qavion F1 World Champ
    14,251
    Ian Riddell
  10. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    461
    London
    Steve C
    That's not wiring the valve open physically, it's installing a switch in the cabin that energises the solenoid. My 5.2 has this setup and it works great, with no lights on the dash.
  11. Mitch Alsup
    Nov 4, 2003
    9,710
    The switch activates the vacuum solenoid, the diode prevents the ECU from knowing.
