Expert advice required - restoring 'cast' metal look | FerrariChat
Discussion in '206/246' started by dantm, Apr 14, 2017.
  1. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
    For the expert restorers here, what can be done for restoring the cast look of an otherwise dull or shiny piece of either aluminum or magnesium?
    Are there guidelines of what cleans up the oxidation/gunk/etc. and leaves the factory cast look?
  2. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,704
    wisconsin/chicago
    bo
    Not a restorer... But blasting with glass beads or walnuts works great...
  3. rosemeyer
    rosemeyer Karting
    Aug 13, 2010
    155
    #3 rosemeyer, Apr 14, 2017
    Not an expert or a restorer but have had considerable experience addressing this challenge in a recent Dino restoration. The general idea is to do the least invasive things first and gradually increase the aggressiveness of your approach as required. It is often very hard or impossible to go back if you ruin/change a casting's natural appearance with overzealous cleaning or blasting. In order, I'd do the following:
    1. Degreasing soap, warm water, brushes and lots of elbow grease
    2. Alumabrite or similar chemical aluminum cleaner (not sure how this reacts with Magnesium so be careful with Mag.) You'd be surprised at how effective this type of chemical can be if you take your time and do multiple cleanings. Wear rubber gloves and safety glasses when using this stuff. In most cases, unless you are dealing with stubborn corrosion or are trying to go after the last concours points, you can stop here.
    3. Blasting with ultrafine glass beads (NOT crushed glass which has sharp edges) at very low pressure. Don't get frustrated as this can be a time consuming process to do well. The glass beads do a wonderful job of getting in every nook and cranny and leaving a beautiful finish. One caveat is to be fastidious about washing any blasted parts to make sure no beads remain in hidden corners, esp. on engine castings. BTW I tried walnut shells early on and I did not get nearly as good a result as with the beads.
    I wouldn't be surprised if there are other blasting techniques, like dry ice blasting, that might yield perfect results as well, but I am limiting my comments here only to those techniques with which I have first hand experience.
    It isn't hard, it just requires patience. Good luck.
    Best Regards,
    Paul
  4. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    More on step 1 Paul noted, try a solvent like lacquer thinners then a soft stainless steel brush.
  5. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,799
    Southern California
  6. JCR
    JCR F1 World Champ
    10,919
    H-Town, Tejas
    Bead blasting will peen over the pores on the light castings. The NCRS guys know about this. It will not look original if that is what you are going for.
  7. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
    #7 dantm, Apr 15, 2017
    Hello and thank you all...
    This is exactly the issue - bead blasting will give a different shine to the material, in some cases based on videos I've seen it makes things have a little sheen to it?
    In my case here's an example of the starting texture of a similar part. Part could be aluminum, or aluminum-magnesium, not sure.
  8. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
    On another thread I read that shot peening may restore the finish to the cast look? Anybody have the experience with this?
  9. pshoejberg
    pshoejberg Formula 3
    1,827
    Denmark
    Peter H
    I use a commercial wheel cleaner fluid product called "ProX". It contains a slight amount of acid, just enough to remove light oxidation from the cast aluminum. This has proven to work like a charm and it does not make any permanent changes to the surface appearance. It is important to neutralize with plenty of fresh water a few minutes after appliance, other than that no further treatment is needed.
    Best regards
    Peter
  10. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    #10 Dave rocks, Apr 15, 2017
    For sand cast (rough and pores) aluminum and die cast (smooth and less pores) aluminum, I use very fine (flour like) glass beads at a lower pressure. This get the metal nice and clean and get in all the small areas. Then I follow up by vibratory tumbling in plastic media.
    Dan - I thought your email was regarding wrinkle finish parted parts....
    Here are some before, in process (only have this photo with steel parts) and after photos:
  11. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,799
    Southern California
    Investigate ultrasonic cleaning. Chuck Stoddard (founder of Stoddard Imported Cars) showed me his personal ultrasonic cleaner in his workshop. He used it for everything from the magnesium engine case of his 917 to plastic interior assemblies of his 911's. They came out like new without any chance of damage. Chuck researches everything he does in his workshop.
    Freeman
    https://www.stoddard.com/aboutus
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    We have a pretty high end Ultrasonic cleaner and while it works very well, it does not remove heavy soiled debris on parts. Our machine cost $10K but it's only 110VAC. Perhaps the 220VAC power sources provide more scrubbing power.
  13. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
    #13 dantm, Apr 15, 2017
    Dave -- your process looks impeccable but I'm not sure if it's what I'm after...
    I'm attaching two more pictures to what I had posted earlier. Keep in mind the above picture was with baked in oils, fuel, etc. stains of 40 years plus. Trying anything mild to clean that (brake clean, dish soap, etc.) did not work.
    Below are two shots - one is the same part 'restored' (not my picture). The darkish gray has been retained - without painting.
    The other shot is my part after using a more aggressive wheel cleaner type 'acid' and following the instructions. It left the surface almost bleached and you can see the original gray in some of the imperfect spots which were maybe a little recessed in the metal.
    So I would assume that finding a process that gets back the 'cast' look to Aluminum would also revert this bleached look. We could of course use manifold gray paint but that's not the main goal.
    Other things that I read about this cast-look restoration invoice: etching chemicals, shot peening, and in one case inline needle scaler to go over the part but I need to find confirmation whether anybody has used that and it worked.
    Thoughts?
  14. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
  15. rosemeyer
    rosemeyer Karting
    Aug 13, 2010
    155
    Dan,
    Based on your last 2 photos this part looks like a manifold. These are typically pressure cast (different surface finish, less porosity, etc.). The use of glass beads, or beads followed by plastic media as indicated by Dave at Sticky RX, works perfectly to restore these parts to as new condition. Don't get too hung up on trying to compare the restored part to a photograph. Clean, newly cast aluminum, particularly pressure cast, is silvery out of the box and typically acquires a darkened cast with atmospheric exposure in a short time. In fact, get a recently cleaned part and rub it with a WD-40 soaked rag and it will already darken a few shades. The photos posted by Sticky RX look absolutely perfect (i.e. as original) to my eye.
    The chemical cleaners always seem to work best on the porous sand cast parts for some reason.
    As others have noted, blasting can seal the pores of cast parts. If you use glass beads, I have to emphasize again to use the finest grade you can get and at LOW pressure. You are not blasting the part as much as using the media to very gently rub away the final bits of contamination and give the part an even finish. It is slow going work to do properly if you go this route.
    Best Regards,
    Paul
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Thank you, Paul. I'm about as OCD as one can get ;)
    100% spot on :)
  17. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
    Thanks -- Paul and Dave one other question...if using glass beads how do you ensure that none will be left in any of the passages/etc. and that can get into the engine later on?
    Are all internal passages taped off at the beginning of the process?
  18. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    LOL - I just stated this in my email to you before reading this post....
    I don't use glass beads on any parts such as cylinder heads, etc. I wish I could as cleaning my head is killing me in time....
  19. rosemeyer
    rosemeyer Karting
    Aug 13, 2010
    155
    Dan,
    I used tape, and lots of it, along with rubber plugs in some cases. In spite of your best efforts assume that some of the beads always find a way through which is why you need to be fastidious about cleaning afterwards.
    In my case I did clean the heads this way but before they left for the machine shop where they would be cleaned again and have all new seats and hardware installed.
    Best Regards,
    Paul
  20. tim@
    tim@ Rookie
    Sep 19, 2006
    29
    Rockwall Texas
    Tim Taylor
    Here is a sample of the Vapor Blasting we do, I have looked for 20 years to find a process that gives me the look of new Cast Aluminum, this looks correct.
    I have never been happy with dry Glass Beading, the parts printed and stained due to the porius nature of the process, Vapor Blast is the way to go.
  21. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    The vapor blasting looks good however, I think it leaves the part too shinny. When we glass blast, one, we use low pressure and second, we vibratory tumble after.
