Experts Using a Tornador? | FerrariChat
Discussion in 'Detailing & Showroom' started by kommons, Mar 7, 2016.
  1. kommons
    kommons Karting
    Sep 30, 2013
    215
    Silicon Valley, CA
    Chris
    Would you please educate me, I just saw this and the idea seems absolutely absurd. Spraying pressurized water inside the car, instruments, in my opinion is bad recipe. I usually get my cars exceptionally clean without liberally getting things wet inside.
    I know I come across as pre-judging but I genuinely want to learn if any of you are using it. How do you prevent things that should not get wet, or grease that should not be removed, or causing undue corrosion or problems in electronics.
  2. V-TWELVE
    V-TWELVE Formula 3
    1,800
    Vancouver, BC
    Can't see it being a problem. it vacuums up the excess water at the same time, the same way a steam cleaner does. It is for upholstery and the surfaces are probably lightly damp after use. I don't think it's meant to clean your car stereo or dash instruments.
  3. Voda
    Voda Formula 3
    Oct 10, 2013
    1,808
    Seattle
    If you try it, make sure to video so you can post it on Youtube.... this oughta be good.
  4. ncjetskier
    ncjetskier Formula 3
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Junk. If you do a search you will see previous posts about what a rip off it is. Not sure how it sucks it up????? The one I own only SUCKS but not up.
