Explosion tears hole in side of Airliner | FerrariChat
Discussion in 'Aviation Chat' started by Tcar, Feb 2, 2016.
  1. Tcar
    Tcar F1 Rookie
  2. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,432
    FL
    Wow that's crazy. I can't imagine what would be in that location that could cause such an explosion other than a bomb. It doesn't look like it was a pressurization issue that ripped it out like that 747 with the cargo door failure that tore a huge hole in the fuselage (United flight 811).
  3. Gatorrari
    Gatorrari F1 World Champ
    16,460
    Georgia
    Jim Pernikoff
    Somalia? I smell a bomb.....
  4. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    I don't know how..... The whole place stinks, you won't smell a damn thing ;)
    I actually haven't been to Somalia but I have spent a bit of time in Djibouti, Ethiopia and Kenya and they are smelly places. Djibouti is the worst, the whole damn country looks like a trash pile from the air. I imagine Somalia much the same.... Almost went into Somalia but fortunately avoided that one.
  5. Tcar
    Tcar F1 Rookie
    That location, between windows. higher than the floor.
    The 'pink' stain down the side looks gruesome.
  6. Tcar
    Tcar F1 Rookie
    Well, we know what the pink stain is.
  7. italiafan
    italiafan F1 World Champ
    16,121
    Stickbones Swagglesmith
    I would kill for that leg room! :)
  8. FERRARI-TECH
    FERRARI-TECH Formula 3
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    Someone did..
  9. Rifledriver
    37,090
    Lets just hope it was the guy with the bomb.
    Question for our airplane builders. How bad would that have been at cruising alt + speed? Could it have been loss of aircraft?
  10. FERRARI-TECH
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    Amen to that..... just read an article reporting that it was an oxygen cylinder that exploded.
    Are they located above or below the passengers ??
  11. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    It also looks about the best place on the fuselage for this to happen? Above the wing where you have a lot of strength?
  12. Rifledriver
    37,090
    If that is true they are lucky that is all that happened. I guess there pressure testing gas bottles is just too inconvenient. We do have procedures to avoid that sort of thing.
  13. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    I think that would be tough to answer without knowing how big the explosive was. It looks like the structure's tear-stop design did its job. The increase in pressure diff. at altitude could enhance the force of the blow out.
  14. Tcar
    Tcar F1 Rookie
    Article I read said that O2 bottles are in the overhead.
    The explosion was not in the overhead.
    Could have been moved down to where the hole is, though.
    Good that it happened at only about 10,000 ft. No decomp.
  15. ypsilon
    ypsilon F1 Rookie
    May 4, 2008
    2,628
    the Netherlands
    Right above the fuel tanks.....
  16. BubblesQuah
    BubblesQuah F1 World Champ
    13,232
    Charlotte
    From inside, still in flight after the explosion. :eek:
    [ame]http://www.youtube.com/watch?v=-XYxvH6ZThU[/ame]
  17. tritone
    tritone F1 Veteran
    7,199
    On the Rock
    James
    Maybe a pax personal oxy cylinder? Not part of the aircraft? Might explain the location....
  18. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    I'm thinking back to the Aloha incident also.....
    I think I'd rather have a breach above the wing than near the front or rear where it has 360 degrees to go at.
    Good point about the tanks though....although a blast big enough to penetrate those would have destroyed the fuselage?
    M
  19. Ricambi America
    Sponsor Owner
    Amazingly calm passengers. Credit to crew, cool heads, and/or shock and nerves.
  20. jcurry
    24,073
    In the past
    Jim
    There was actually a window there. Blew out between frames, although the fwd frame appears to have substantial damage. Upper extent of the damage is a longitudinal skin splice, which makes sense given how clean that edge is. The longitudinal rip below the window on the fwd side would be along the lower edge of the window belt (skin is doubled or even tripled along the window).
    Its an A321. Only plane in their fleet (Daallo Airlines), 19 yo (the plane).
    A bit fwd of the wing. The front spar would be where there is a gap in the windows.
  21. action-ant
    action-ant Karting
    Nov 16, 2015
    179
    San Francisco, CA
    Anthony
  22. Tcar
    Tcar F1 Rookie
