Extended guarantee on a Portofino | FerrariChat
Discussion in 'California/Portofino/Roma' started by cyr, Mar 11, 2025 at 10:00 AM.
  1. cyr
    cyr Formula Junior
    Jan 28, 2020
    285
    Cy
    I extended the standard warranty period on my 2020 Portofino in 2023 for two years.
    The left full beam headlight does not work anymore. The normal headlights do.
    I am going to the deale tomorrow for him to look at it.
    Anyone know whether this will be covered by the guarantee? Usually just about nothing is covered by the guarantee, but I would like to know before the dealer says "no".
  2. Zarakoff
    Zarakoff Karting
    Jul 8, 2020
    93
    Uk
    Ian Curley
    You’ve extended the normal warranty here by 2 years so if like mine that means it’s the same as the first 3 years manufacturer (I did think it was 4 years first warranty) which they allow 2 years to be added after that it’s the power warranty that’s not as good .
    So that should mean anything wrong like the light failure for sure will be covered but you’ve got a bulb gone I’m thinking that’s a consumable ( can you even just replace a bulb on these ? )
  3. cyr
    cyr Formula Junior
    Jan 28, 2020
    285
    Cy
    False alarm. Apparently there is nothing wrong with the bulb, even though it did not work for a while. Works now, so hopefully it will keep working.
    Thanks for your reply
