Extending life of fog lights and window gaskets on 348. | FerrariChat
Discussion in '348/355' started by 76Steel, Apr 29, 2015.
  1. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,482
    New Jersey
    Hello,
    Did anyone put any of that helicopter clear tape to protect the fog lights on their 348? I'm thinking of doing so to protect the expensive light.
    Additionally, do you use anything to lubricate the rubber "gaskets" that touch the passenger/driver door glass? I was thinking of a smidge of WD40, but wondering if the stuff
    is not perfect for the rubber trim.
    Thank you. Just curious, simple couple questions.
  2. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    I'm curious if anyone has found precut protector film for the fog lights on a 348. I was surprised Xpel doesn't show it, but maybe it's part of their headlight protection kit. I keep meaning to contact them to find out. If not, and assuming I can't find any elsewhere, I'll just get some Xpel sheets and cut them myself. If you find a better/easier alternative please let us know.
    As to the rubber weatherstripping, a great product designed specifically for that purpose is called Gummi Pfledge. It's available from quite a few vendors, as well as Amazon.
  3. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,482
    New Jersey
    Mike,
    Right. I just want to lubricate the weather strip stuff to clean it and make the glass go up/down easier. I usually go with some stuff from Chemical Guys on rubber stuff, but for this purpose I thought I'd ask.
  4. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    I've just had my 348 foglights covered with ventureshield and putting together a kit for other parts on the car.
    Will post pics and info on another thread later today.
  5. ff355b
    ff355b Karting
    Feb 26, 2010
    218
    I've used a simple paste wax before and it made the surface of the glass smooth. FYI, I've only tried this on the exterior side only.
  6. GTSNJ
    GTSNJ Formula Junior
    Jan 18, 2015
    478
    I use dot 5 pure silicone brake fluid on a rag it really dresses rubber nice. Apparently its an old biker trick for rubber and plastic parts. Wd40 in my experience looks good initially and then dries out quick.
    For armor all type products , they look nice but tend to fade quick.
    Turtle wax ice liquid also dresses up seals nice. I have them all if you wish to try.
  7. janders82
    janders82 Karting
    Nov 26, 2014
    180
    Atlanta, GA
    interesting. Can the silicone based dot-5 end up "shrinking" the rubber over time? I've always been told to stray away from products like Armor All and other silicone based "conditioners." Also, not sure if I'd use WD40 as it is not technically a lubricant, but actually a solvent.
    I'm kind of wanting to try the dot-5 though...
  8. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    I have used a number of items and find this also to be the best. It is available at BMW dealers as well. Very good rubber lubricant.
  9. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    Product called " ru-glyde " is a rubber lubricant and preservative . Does not contain silicone .
    1994 ferrari 348 spider , third owner purchased may 2013 w/ 27804 miles
  10. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    #10 3forty8, Apr 30, 2015
    Xpel makes a pre-cut kit for 348 fog lights, I purchased a set years ago directly from them:
    https://www.xpel.com/products/headlight_protection.asp?prevtype=1&prevyear=1992&prevmake=44&prevmodel=0&prevsubmodel=0&prevseries=0&type=1&year=1992&make=44&model=3199
  11. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    #11 SoCal1, Apr 30, 2015
    Did mine in yellow with 4mil sheets
    On vinyl or plastic I use
    303 Aerospace Protectant
    Stay away from armoral it breaks down the rubber
    303 is the only thing that works on my spa cover here in the SoCal sun.
  12. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,901
    Richmond
    Pete
    Leatherique supposedly works well to preserve rubber. I put some on my gaskets last time I conditioned the interior of my car, certainly didn't hurt anything.
  13. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
  14. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,482
    New Jersey
    Aerospace 303 is great. I use it on many things like rubber, wheels, dash. Non sticky and gives a nice pro look. I want to lube the seals a bit, clean ... I might check out the Gummy product Mike recommended. Found it on Amazon for $10.
    Cool on the fog protectors. Thanks for the tip.
  15. Stephen C
    Stephen C Rookie
    Nov 10, 2013
    25
    Calgary
    Steve C
    For fog light protective film, I went with LaminX. I used the yellow. It went on easily and looks good.
    The precut lens covers use a film that is fairly thin but they tell me it works well for the service. They have thicker bulk product but I think it might be too stiff and would struggle staying fixed given the curve of the fog light lens.
    Cheers
    S
  16. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Did mine years ago. Made a template - I'm sure I can find it somewhere - bought the material from a BMW parts retailer on line and did the whole thing in an hour or so.
  17. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 ...... I saw the finiished work on these and the thick pliable plastic used, looks like a factory made solution .... :)
