F-1 problems | FerrariChat
F-1 problems
Discussion in '360/430' started by MalibuGuy, Jan 17, 2010.
  1. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,901
    I noticed that my F-1 warning light would flicker sometimes when downshifting at low RPMs particularly from 3 to 2. So I brought the car in to the dealer. The SD diagnostics showed no error codes and they gave the car a clean bill of health.
    Last night, the car got stuck in second gear! Would not upshift or down-shift. Finally got neutral and pulled over. The F-1 warning light was flashing and after turning the car off and re-starting couldn't get any gears. Then after a few minutes of pulling paddles I get second gear and decided to try to limp home. This was a tough call because I couldn't shift into any other gears including neutral!
    Got almost home but then stalled in second. Couldn't restart the car because it would not go into neutral. After letting the car sit overnight, I turned the key (foor on the brake) pulled both paddles and the car went into neutral!
    So I start the engine and now the F-1 light is a steady "ON" and not flashing. Obviously this indicates an even worse problem.
    Turned the car off and tried to re-start but now the car won't even crank. Checked the battery which is fine. But when I open the door or turn the ignition key, the F-1 pump does not prime at all! What does this mean?
    Plan is to flatbed back to the dealer.
  2. wahoowa
    wahoowa F1 World Champ Silver Subscribed
    Aug 7, 2008
    10,971
    _East Coast_
    Bill
    Possibly?:
    http://www.ferrarichat.com/forum/showthread.php?t=255013
    Keep us posted on the outcome
  3. blackbolt22
    blackbolt22 F1 Veteran Silver Subscribed
    Sep 25, 2007
    5,808
    Boca Raton, FL
    Mr. Anderson
    These F1 problems would drive me nuts. Best of luck. Hope it isn't serious.
  4. MalibuGuy
    Sep 18, 2007
    5,901
    Preliminary report is that the hydraulic pump is bad. A new one is about $1500.
    But still waiting to see what other problems exist?
  5. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Pump unit is the same as the Maserati unit but the Ferrari one is twice the price. Same part number too...
  6. Eric360
    Eric360 Formula 3
    Jan 11, 2010
    1,428
    San Francisco, CA
    Eric
    That is soooo wrong!
  7. BJMoravek
    BJMoravek Formula Junior
    Jun 4, 2008
    462
    Boondocks, Maryland
    No. That is sooooo Ferrari....
  8. blackbolt22
    Sep 25, 2007
    5,808
    Boca Raton, FL
    Mr. Anderson
    LOL. Good one.
  9. MalibuGuy
    Sep 18, 2007
    5,901
    Got a new pump and relay and everything is perfect!
  10. kaamacat
    kaamacat Formula 3
    Jun 13, 2004
    1,623
    Cumming GA
    BobR
    Sad that Ferrari has had so many of these failures of that POS pump/relay on the 360's and unfortunately gives what is a pure blast to drive such a bad name when people are looking at them and 99% of the time the F1 issue sways people in another direction. (Let alone what the real cost for that small pump probably is in real life). That could easilly be a recall item!
  11. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    Hey, it costs a ton to print those horseys on the box!
    Dave
  12. Eric360
    Eric360 Formula 3
    Jan 11, 2010
    1,428
    San Francisco, CA
    Eric
    They should raise the price of the Maserati pump!
  13. MarvelComics
    MarvelComics Rookie BANNED
    Dec 20, 2009
    40
    How much did it cost?
  14. MalibuGuy
    Sep 18, 2007
    5,901
    Shhh! Don't give those guys at Maranello any ideas!
  15. MalibuGuy
    Sep 18, 2007
    5,901
    Sorry but I am sworn to silence. (Ricambi America can tell you though!)
  16. Eric360
    Eric360 Formula 3
    Jan 11, 2010
    1,428
    San Francisco, CA
    Eric
    Twice the cost of a Maserati pump...
