F 360 Spider-battery turned off-how to open trunk without power?? | FerrariChat
Discussion in 'Technical Q&A' started by peterpertl, Mar 29, 2008.
  1. peterpertl
    peterpertl Rookie
    Mar 29, 2008
    6
    I have a huge problem. I hope that there is anybody out there who can help me.
    I turned off the battery in autumn and I will turn it on now, but I have closed the trunk and I can not open it without power of the battery... so is there a chance to find a switcher to open it without power like an emergency release??
  2. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    6,098
    Hi-
    I own a 360 and in my car there is a small cable under the driver's side dash which will release the trunk. I often use this when I am outside the car so I dont have to get in and operate the electronic button.
    I am not positive that the F430 has this feature but you can easily check it out.
  3. peterpertl
    peterpertl Rookie
    Mar 29, 2008
    6
    many thx . found it! best regards from austria
    peter
  4. MalibuGuy
    Sep 18, 2007
    6,098
    Hi Peter-
    Greeting from California. I have visited Salzburg several times. The lakes around the Salzkammergut are lovely.
    There are also a few other hidden small wire releases you should know about: in the fuel filler area is one for the engine lid and along the right front wheel well is a small loop release for the trunk safety lock lever.
    Milton
  5. Night life
    Night life F1 Veteran
    7,322
    The city that rhymes with fun in Canada
    Roberto
    Hey Peter didn't you get a manual for your car and if not get one...:p
  6. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    Another option would be to charge your battery through the cigarette lighter (depending on if the lighter has been wired to the battery directly or through you ignition key)
    Hans
  7. peterpertl
    peterpertl Rookie
    Mar 29, 2008
    6
    the manual was in the trunk during the winter- so I can`t read it and find a solution.
    peter
  8. Night life
    7,322
    Roberto
    OH! That sucks......:(
  9. lmunz22
    lmunz22 Formula 3
    Jan 16, 2007
    1,224
    Wouldn't it be much better to hook up a battery tender?
  10. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    Now you've got to put the codes in for the radio, etc. a real pain. Use the tender, plugged into the lighter.
    Art
