F-40 Front Compartment (Bonnet - Hood) Retaining | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by 512Tea Are, Dec 7, 2007.
  1. 512Tea Are
    512Tea Are F1 Rookie
    Apr 22, 2004
    2,742
    Dear F-40 Comrades,
    The F-40 has a total of four retaining studs that hold the Bonnet/Hood and Rear Engine Cover in place. Those on my car, as with many others have become just a little corroded. Accordingly, I should like to remove them and have them replated. However, the Allen screws that retain them appear to be impossible to remove - is there a special technique of which I am unaware that should be applied?
    I thank you in anticipation of your thoughts in this regard.
    With kind regards,
    512 Tea Are
  2. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    Impossible to remove due to corrosion? If so some penetrating fluid used liberally and re-applied and soaked in, should loosen them up.
  3. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Graham,
    They need to be re-anodized. They look fantastic when re-done.
    Joe
    www.joesackey.com
  4. 512Tea Are
    Apr 22, 2004
    2,742
    Dear Comrade joe sackey,
    But do you have any idea, please, how they should be removed? The countersunk retaining screws appear to have a hexagonal aperture for inserting an Allen key. The aperture is relatively small for the size of screw as of ocurse is the corresponding Allen key. I have wrought as much pressure upon the key as I dare and it seems very solidly retained to the extent that the key will turn in the aperture should I apply further pressure. Is there something here that I should be doing that I am presently wholly unaware? I do realise that lubrication may help - but is it just a case of lubrication?
    All good wishes.
    With kind regards,
    512 Tea Are
  5. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    I think that the proximity to the inside wheel well has afforded a bit of corrosion the opportunity to cause the aforementioned screws to seize. Pehaps some pics will clarify? To be on the safe side, I would have the techs at Ferrari handle the problem if you fear that you are about to inflict damage upon your flawless F40.
    Joe
    www.joesackey.com
  6. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Graham,
    maybe age has atrophied your biceps....perhaps a younger buck might do the trick ? :)
  7. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Fly me over and I'll take care of it for ya Graham. :)
  8. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    The way you carry on about 512 Tea Are being a pensioner one could be forgiven for thinking that YOU are so young and so strong... is that the case? Pray tell us...
    Joe
    www.joesackey.com
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I suspect that a properly sized Allen socket and the careful application of an impact gun (after the penetrating oil has had some time to work) will do the trick.
    Of course don't forget: "righty tighty, lefty loosey" ;^)
  10. carsinxs
    carsinxs Formula Junior
    Feb 26, 2007
    699
    On The Fence
    H
    It would be my pleasure to assist Jas if any additional muscle is needed. I doubt it would be necessary with his 11 yrs of mixed martial arts training however.
  11. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    LOL.
    Joe
    www.joesackey.com
  12. carsinxs
    Feb 26, 2007
    699
    On The Fence
    H
    I believe you actually challanged him to a "match" in a previous thread. 10oz. gloves as I recall.
  13. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Anytime.
    However I beleive the idea was borne, suggested and promoted by a certain 512 Tea Are. Surely by now you have caught on to his sarcastic repose?
    BTW, the man started a thread here seeking maintenance assistance with his F40. As usual, Rough MD and yourself have little to conribute that is actally of some viable USE to an F40 owner in need of assistance. Please feel free to make an attempt at proving me wrong....
    Joe
    www.joesackey.com
  14. Tarek K.
    Tarek K. F1 World Champ
    10,798
    Cairo - Egypt
    Tarek K.
    :D:D............Graham, lots of WD40 and leave it to sink in for a day. You should be able to easily unscrew them afterwards.
  15. 512Tea Are
    Apr 22, 2004
    2,742
    Dear Comrade SSNISTR,
    Yes. One of my very good friends is an Airbus Pilot for Virgin he generally flies the long hauls from Heathrow down to Australia plus other far distant destinations. However, he does on occasions fly into New York and which, as an aside, I understand to be poorly lit with runways scarcely large enough for the Airbus. The question is, how far are you from New York :)
    With kind regards,
    512 Tea Are
  16. 512Tea Are
    Apr 22, 2004
    2,742
    Dear Comrade carsinxs,
    Yes, okay, you can come over Business Class - how far are you form New York :)
    With kind regards,
    512 Tea Are
  17. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Yes it is.
    By the way, Graham can take a joke, why are your panties getting in a wad ?
  18. carsinxs
    Feb 26, 2007
    699
    On The Fence
    H
    I see you had to think about that one for a while as your typical immediate response was not forthcoming. Bold as it may be since we've all seen the dystrophic stature. You see, sarcasim is not exclusive.
    As to the sarcastic one's dilemma, a good soaking with a penetrating oil, WD40 as above or "breakaway". Neither available, ask the local hardware attendant for their rec. Make sure it won't harm the paint. Reapplication several hours after the 1st time it was put on. Let soak for a day or two as previously suggested. Then, check the size allen wrench needed, go buy a new quality one so it has no slightly rounded edges that may "appear" OK from the likely used garage set. We don't want stripped heads. Put the short end of the wrench in, tap lightly with a hammer to seat the wrench and apply even, increasing pressure until the badboy breaks loose. Repeat.
    Oh, and business class is fine 512TR. :)
  19. 512Tea Are
    Apr 22, 2004
    2,742
    RufMD is a well worn forty eight. For myself, I am in superb condition and will convey to you an image of myself within the blue F-40 LM Pilot thus to wrest any anxieties that the RufMD may have. My understanding is that he has an urgent desire/need for a mission as emissary for the Ferrarichat.com in his assumed role as my personal physician and now seeking the merest hint of an opportunity of flying into his erstwhile homeland of England for Christamstime.
    All good wishes.
    With kind regards,
    512 Tea Are
  20. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    I share your frustration on screws that won't budge. I read the thread in the hope that somebody might offer something useful. WD40, impact wrench, etc are at least on topic. Would it help after the WD40 has had a chance to work to tap the Allen key with a hammer?
    If you can lift the front and rear shells your biceps are more than a match for allen screws :):):)
  21. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Ahhh, your age estimations once again betray the effects of age induced dementia....guess again old boy ! I regret to inform you I cannot accept the role of your personal physician. One must understand ones own limitations, and my geriatric and psychiatric background is limited. :) Since my age is a concern of you both, I will go on record and admit to being a very young 40 years of age...life begins at 40, no ?
    (***As an aside, the " :) " means its meant in jest Joe...go back and look at the original post and see if you can find it***)
  22. 512Tea Are
    Apr 22, 2004
    2,742
    Dear Comrde DM18,
    I believe that Carsinxs has come up with the difinitive remedy. Accordlingly, I am to mould a product that we have here called 'Blu-tac' into a circle and thence from will fill the little pool thus formed with WD40, and leave it to penetrate for a few days. I shall then follow the further advice that Carsinxs has extrapolated.
    All good wishes from England.
    With kind regards,
    512 Tea Are
  23. 512Tea Are
    Apr 22, 2004
    2,742
    Dear Comrade RufMD,
    Yes, I had originally presumed you to be forty. But I had no wish to offend you and therefore conveyed a little further maturity to your tender years. I have done the same for Joe Sackey who is only twenty eight. I have made him forty as I do not wish either of you to think that I believe you to be immature and feel a moral obligation to treat you both with similar affection :)
    All good wishes from England where it is presently raining stair-rods.
    With kind regards,
    512 Tea Are
  24. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Good wishes to you too Graham....have a Merry Christmas and a Happy New Year ! All the best to you and your family.
  25. 512Tea Are
    Apr 22, 2004
    2,742
    Dear Comrade RufMD,
    Thank you for your kind sentiments which I return herewith manifold to you and your loved ones.
    The Macmillan cancer charity has been here this morning photographing the motor car. Our Ferrari Area Group (FOC UK ) has published a calendar for 2008 with our cars on it. All the money from the sales is going to Macmillan hence the photo-shoot today for the press photograph's.
    With kind regards,
    512 Tea Are
