F 40 optimum water temperature | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by coachi, Jul 17, 2007.
  1. coachi
    coachi Formula 3
    May 1, 2002
    2,108
    SC USA
    What is the optimum water temperature in your F 40 ?
    When do your radiator fans kick in? How difficult is it to bleed the air out of the system. I know the bleed valve is behind the seat behind the firewall.
    Thanks in advance for your responses.
  2. coachi
    coachi Formula 3
    May 1, 2002
    2,108
    SC USA
    surely someone who owns an F40 and reads this column can tell me what his temperature gauge reads when he is driving his car? thanks again
  3. 512Tea Are
    512Tea Are F1 Rookie
    Apr 22, 2004
    2,742
    Dear Comrade coachi,
    Will you elaborate a little further, please? What exactly is your concern - is it that you believe there to be a problem with a cylinder head gasket, the water pump or perhaps something else? The water temperature on my own motor car, a 1992 model, does vary significantly with the extent of the ambient temperature - as of course does the oil temperature. So please let me know what you believe your problem is and if I am unable to assist you directly (I am by no means an expert) I can enquire at my local dealership on your behalf and I feel quite certain that they wil be able to provide a list of probable resolutions.
    With kind regards,
    512 Tea Are
  4. coachi
    coachi Formula 3
    May 1, 2002
    2,108
    SC USA
    well, my normal temperature is around 195 when driving the car. I suspect air is trapped within the cooling system, as I had to replace the thermostat to the radiator fans and am not sure I have bled all the air out.
    Thanks for your help
  5. 512Tea Are
    Apr 22, 2004
    2,742
    Are you situated a long way from someone who has expertise with an F-40?
    I should be pleased to speak to my Ferrari dealer tomorrow if this would help. It would be foolish of me to proffer advice as my expertise is negligible. Furthermore the ambient temperatures within England are presently so much lower than in your clime to make any comparison of no use whatsoever.
    Let me know please.
    With kind regards,
    512 Tea Are
  6. 512Tea Are
    Apr 22, 2004
    2,742
    Dear comrade coachi,
    With regard to my sojourn to London today and particularly the travail within the city itself.
    I can confirm that at no point did the temperature gauge of the F-40 exceed
    ninety five degree's. For the most part it was stable at ninety degree's. The ambient temperature here today was circa seventy degree's fahrenheit and it may well be likely that the ambient temperature in your situation may be far higher. Certainly, your water temperature is far higher than that shown on my cars thermometer today. Could it be that your gauge is reading incorrectly as I cannot even begin to understand how your temperature could be double that of my car?
    I am sorry that I cannot help further, but my expertise in these matters is not at all great. However, I do hope that everything is resolved to your satisfaction very quickly.
    With kind regards,
    512 Tea Are
  7. coachi
    coachi Formula 3
    May 1, 2002
    2,108
    SC USA
    my temperature is in degrees fahrenheit, yours must be celcius, 90 degrees would read 195 approximately on my thermometer, so we are spot on. My fans kick in around 200 degrees, and cool the coolant back down so that the engine does not overheat.
    I am amazed that no USA owners have chimed in. I know there are at least 200 of them, and some are very good friends. It appears that my temperature is fine, as far as an upper limit is concerned. I am sure the car would run a bit better if water temperature was a bit lower.
    Thanks for your input. I am grateful.
    There is another thread about what seems to be "loss of power" or boost power in the supercar chatroom. I have just started following it. Basically I am not feeling the diabolical boost the car had a few months ago and am investigating reasons. It is hot these days in the southeastern part of the US, and that may have something to do with it.
  8. 512Tea Are
    Apr 22, 2004
    2,742
    Yes, I do understand your disappointment that none of your countrymen have assisted on this post. However, it would seem from the inordinately low mileage of their cars that many of them do not drive their cars at all. Therefore they would not be able to proffer any practical assistance - so don't feel too badly about this.
    I am sorry that I neglected to inform you that the cooling fans on my car switch on at the aforementioned temperature of ninety degree's which seemingly accords with your car. It would seem therefore, and please, I have no real expertise in these matters, that your car, on the face of it, does not appear to be running overly hot. Which, if this is indeed the case, is very good news indeed.
    With kind regards,
    512 Tea Are
  9. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Surely the nearest authorised Ferrari dealer can be helpful?
    Joe
    www.joesackey.com
  10. Simon^2
    Simon^2 F1 World Champ
    Oct 17, 2005
    12,313
    At Sea Level
    PM sent. not much help, but i'll check exact temp next time I drive her, and let you know.
  11. cmparrenzo
    cmparrenzo F1 Rookie
    Mar 3, 2002
    2,687
    Kansas
    Chris Parr
    Ok, 195 is normal. If it is a cool day, 175 can be seen. A F40 will heat up if driven slowly even in cool temps.
    Extremely hard driving on the track in summer will yield 210 to 215, I never had a true overheat issue even in the most extreme cases.
    You are perfect at 195.
  12. Jati
    Jati Formula Junior
    Dec 3, 2004
    299
    Florida & NC
    Joe G.
    Hi Coach,
    I drove mine around a bit yesterday....The temp gauge was reading 195
    After I backed in to the garage, before shut down, the cooling fans came on and at idle the temp dropped to 190.
    Hope this helps.
    Joe
    PS. I suspect that your seeming loss of boost would be attributed to the hotter summertime temperature.....Lets look into air to water intercoolers.... :)
  13. coachi
    coachi Formula 3
    May 1, 2002
    2,108
    SC USA
    Actually, a previous owner had installed a water injection system to cool mthe oversized intercoolers, but it is not working, perhaps the motor is dead or disconnected, I need to look into that...
    I have been told that it is best to let the car idle for a while after a good drive, to let the turbos and whatnot get back to normal before turning the engine off.
  14. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    NA cars are effected by the heat even more....consider yourself lucky LOL.
  15. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Coachi,
    Tonight I took the F40 out for a good "seeing to". I added a splash of fuel and off my son & I went driving fairly hard with the turbos spooling up and 'wooshing' away repeatedly with every shift. It was a spirited dive, BUT the key was that it is a cool evening at just 70 degrees on the Pacific Coast. The needle never went above 180 proving the other's theories that these cars run cooler in the cool weather, and hotter in the hot weather. BTW, in the cool evening air, the car felt like a rocketship. Hope Ive helped.
    Joe
    www.joesackey.com
  16. Chaos
    Chaos Formula 3
    Sep 29, 2004
    2,346
    Cardiff. UK
    Nick.
    cant agree with that.
    every turbo car ive had (or my friends) has been way more affected by ambient temerature than any n/a
    i always thought this was generally well known
  17. Jati
    Jati Formula Junior
    Dec 3, 2004
    299
    Florida & NC
    Joe G.
    Cooler air = Denser air= more efficient combustion.
    With so much heat in the engine bay of the F40's ...I doubt the intercoolers are doing what they could if located in a better/cooler environment.
    The heat coming off the header tubes on the Enzo, rising up through the vents, is viciously hot....IMHO, the car needs cooling/exhaust fans for the engine bay.
    JG
  18. Steve
    Steve Formula Junior
    Nov 1, 2003
    901
    Seattle, WA
    Steve Jenkins
    Mine will hit 195 in hot weather if I'm in traffic, but hovers around 180 as long as I keep her moving. :)
  19. Chaos
    Chaos Formula 3
    Sep 29, 2004
    2,346
    Cardiff. UK
    Nick.
    how about lagging the headers and turbos ?
    that should help drop engine bay temps
  20. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Not quite true, you just might notice it more then a NA car. Look at how forced induction cars perform better at higher elevations then NA cars. Same basic theory.
    Bottom line, excess heat effects ANY engine.
  21. SRT Mike
    SRT Mike Two Time F1 World Champ
    Oct 31, 2003
    23,343
    Taxachusetts
    Raymond Luxury Yacht
    This is untrue.
    N/A cars and FI cars will both suffer with higher ambient temperatures, but it's a totally different effect to the altitude thing. FI cars do not suffer much at altitude whereas NA cars do. This is because FI (turbo) cars build a given amount of boost in relation to sea level - so if you run 15lbs at sea level you also run the same density (higher actual boost pressure) at altitude. NA cars don't. NA cars get less dense air at altitude.
    The FI car is going to have a higher delta between intake and exhaust temps at the turbo at altitude than at sea level, which decreases the gains a bit, but both will be affected by temperature, IMO the FI car moreso.
    But the altitude thing is very different than the temp thing in comparing performance of NA vs. boosted cars.
  22. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Humm, that's what I said?
    I said NA cars are effected much more then FI cars at higher altitudes....
  23. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    concur @ 195 and lower when cruising
