F1 Actuator repair/replace options? | FerrariChat
Discussion in '348/355' started by Drock28, May 9, 2018.
  1. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    hi there,
    been doing some research.. regarding the 355 F1 system..
    theres lots of info regarding upgrading to the 360 pump/motor combo kit, which is conveniently available from Hill Engendering..
    however could not find much regarding solutions for when the Actuator fails..?
    thanks in advance..
  2. phrogs
    phrogs F1 Veteran
    7,341
    Kzoo Michigan
    WATSON likes this.
  3. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    hi thanks for the inputs..
    my inquiry is more for my own knowledge to understand the F1 system better.. since I have a manual car.
    however would not shy from an F355 F1 if something comes up..
    at the same time I have an acquaintance who is selling a 98 spider F1.. and he reports the actuator is done.. was leaking and car would not go into gear
    he got quote from Ferrari dealer $7500cad just for the actuator.
    I am unaware if the diagnosis is correct or not..
    however from what I do know.. I thought the weak spot was more the pump/motor..?
    how common is it for the actuator to fail..?
    now that im aware of the solution for the pump/motor was hoping there were options for the actuator other then buying used/rebuilt etc..
  4. WATSON
    23,677
    WI
    How much he want for the car. Now that the F1 system us FUBAR'd? Just curious.
    I might be willing to take on a yuuuge project if the price is right.
    Tarek307 likes this.
  5. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    It's an hydraulic actuator. Most certainly repairable. No fairy dust inside. I'm Trying to get my hands on one to dissect.
    phrogs likes this.
  6. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    its a 1998 Spider, Canadian car
    yellow/black
    27,700kms
    red calipers
    challenge grill
    Tubi Exhaust ( rest stock)
    Engine out due
    airbag pulling, potential other stickies
    currently not driveable as described above
    minor oil leak from main line below
    accident report/claim for front bumper
    do not know status/functionality of the top.
    he's asking $55,000 CAD.
  7. WATSON
    23,677
    WI
    True. It's just a car...and just an actuator. But the pieces might be unique (although I suspect not).
    I never opened one up, but didn't some post about a rebuild effort on one a while ago? Seattle if I recall. Maybe that was the solenoid assy.
    Anyway, I might know where a "disabled" one might be. Let me check next week when I can stop in there.
  8. Skippr1999
    Skippr1999 F1 Rookie
    4,497
    Previously posted, but they’ve been around a while for rebuilding your actuator.
    GTE Engineering LLC
    561 NE 26th CT
    Pompano Beach, 33064 FL
    TEL 1 (754) 205 0812 M-F 9am|5pm
    Hopefully someone will use this service and report back.
    tres55 and WATSON like this.
  9. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Without question the components are unique but everything can be reverse engineered;)
  10. tres55
    tres55 F1 Rookie
    3,568
    Canada
    GTE Engineering is the go to as far as I know. I'll be dissecting my system this summer. Its not rocket science...but retail side has a heavy Ferrari tax.
  11. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    ok good.. although ive never heard of them, looks like theres a support base for GTE.. theres no pricing on their site.. but their ebay listing is $3600USD for the rebuild..
    I guess that's fair/reasonable..
  12. Skippr1999
    4,497
    Definitely reasonable compared to the old school alternative of 28k !
  13. WATSON
    23,677
    WI
    I think that $28k was if the electrical motor died on the system.
    Instead of replacing just the electrical motor, Ferrari was selling the entire solenoid assembly as the fix....$28k. + installation and SD work.
    The actuator repair would be on top of that. Although that would probably be $28k too. Nose hit. :eek:
    Now? We have $500 motor replacement options. $400 accumulator bulb replacements.
    What we need are some solid rebuild options on the actuator and the solenoid valving on the assy.
    Getting there....
  14. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    the way I see it.. this would be a summary of the more likely potential issues encountered with the F1 system.
    Actuator failure = $3600 rebuild ( GTE Engineering)
    Electric motor failure = $450 ( Hill Engineering)
    Electric motor+360 pump combo upgrade = $1100 ( Hill Engineering)
    Gear Display failure = $145 ( Hill Engineering)
    accumulator bulb replacement = $425 ( Ricambi)
    assuming the rest in between is pretty much safe.. as the above is was seems to me what most people talk about..?
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    360 conversions are no longer needed with a couple options to just replace the pump motor.
    WATSON likes this.
  16. WATSON
    23,677
    WI
    The only piece missing from that list are the solenoids on the shifting assembly.
    As Dave noted, we don't have to do the 360 conversion unless we want to now.
  17. Skippr1999
    4,497
    What are the current choices for this upgrade?
  18. WATSON
    23,677
    WI
    The electric motor?
    Full 360 conversion using the Hill adapter block from Ricambi. Juri has some alternate motor options as well.
    Or
    OEM style, drop in replacement motor from Juri or Dave...at least I think Dave has it now.
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    No, we do not. I've not developed anything yet and don't know if I ever will. I bought a 430 pump motor and had (long down the priority list) plans to make an adapter plate. What Juri has seems to work OK but I'm not particularly in love with the quality of the manufacturing. I don't know if he makes the motors or purchase them. Honestly, I don't even like to mention his offerings as it's providing him free advertising for someone who I question his business ethics.
  20. WATSON
    23,677
    WI
    I thought you had that 355motor option done.
    As for Juri, he doesn't participate here as a sponsor so that's fair.
    In the name of equal time, I have worked with Juri for several years now and have had zero issues and he is quite helpful.
    I have his "heavy duty" 360 motor installed and it is top notch. So, there is that.....
  21. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Sent you a text :)
  22. WATSON
    23,677
    WI
    Thanks.
    But, if you don't have the 355 OEM motor, Juri is kind of the only option...and so far my experience has been fine.
