F1 car bore/stroke?
Discussion in 'F1' started by Mr Payne, Jun 7, 2004.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. Mr Payne
    Mr Payne F1 Rookie
    Jan 8, 2004
    2,870
    Bakersfield, CA
    Payne
    Why do F1 cars have 2:1 bore:stroke? Why not a 3:1 bore:stroke? Is it just the average horsepower will be less due to the loss of area underneath the torque curve? Will the gain in revs not be worth it?
  2. beast
    beast F1 Veteran
    May 31, 2003
    8,584
    El Paso, TX
    Rob Guess
    In 2000 the Ferrari F1 motor had a bore of 96mm and a stroke of 41.1mm giving a bore to stroke ratio of 2.31:1
    Now if we take a look each cyl we can see at 18,000 RPM the piston moves up and down 300 times second!!! and each valve is opening and closing 150 times a second!!! Now go and figure the time it takes for each of the 4 cycles of a 4 stroke engine to take place at this RPM.
    If we shorten the stroke and increase the bore for a 3:1 ratio IE a 105mm bore and a 34.5mm stroke could increase the maximum RPM and cause a reduction in torque. The biggest problem would be the fact that the engine would now more than likely have to go to 2 spark plugs to ignite to fuel air charge and the extra spark plug may cause problems with cam shaft support areas, Combustion chamber + Piston design, and port shapes.
    The trade offs versus the increase in width of the engine and lowering of the CG of the engine just dont work. As with anything mechanical in nature. there are trade offs that have to be made in order for the project to go ahead.. Including a F1 race car and motor.
    Beast
  3. beast
    beast F1 Veteran
    May 31, 2003
    8,584
    El Paso, TX
    Rob Guess
    Beast
