F1 Clutch Job | Page 13 | FerrariChat
F1 Clutch Job
Discussion in '360/430' started by Andrie, Jul 18, 2016.
  1. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,899
    Central NJ
    Dominick
    As of March Ferrari and Maserati are still at 10.26
    I did see release notes that said it addressed the issue in one the releases but I did also hear more than once that it wasn't truly fixed
    I am too curious to get positively positive confirmation
    Thanks Dominick
    Sent from my Moto G (4) using Tapatalk
  2. evilruss
    evilruss Karting
    Jan 27, 2015
    57
    Rockford
    Ok, then I have the most recent version of 10.26 but also don't believe it was fixed yet. I'll try to confirm that this weekend though on my 430.
    billy.gif Formula Junior
    Mar 9, 2017
    259
    Finland
    Here's my story about really confusing F1 clutch wear rate:
    My clutch was changed at May 2017 after a metal part from the clutch plate broke off:
    Parts which were changed are same that comes with the Ferrari "OEM Clutch Kit":
    -flywheel
    -clutch disk
    -throw out bearing
    The clutch was calibrated with 3rd party software said being able to calibrate the gearbox / TCU.
    During summer months 2017 I drove the car little over 5k miles and gearbox / clutch worked almost flawlessly, maybe 5 times it chose 2nd after sitting with N as I was trying to accelerate from the traffic lights. Once it wouldn't choose any gear after sitting in N for 1-2min. Solution was to restart the car and after all worked well. It never lit nor flashed the dreadful "gearbox warning light" or the F1 pump never primed longer than maybe 8 sec at max. Then I parked the car for winter months.
    Now after 5 months or so I took it to the spring service (all fluids etc.) and while I was driving there, after 10 miles I stopped to the traffic lights, put gearbox to "N" and waited like 1 min for lights to go green. Then ... nothing. Car wouldn't go into any gear, not even after multiple restarts and pushing the car a bit. Every time I shut car down it was at "N" when I put ignition back on and restarted it. I thought that maybe cold weather or long period of inactivity or low battery voltage is the culprit as the temp was around 28F or -2 C and she flashed "ASR" once when I started her up (connected to the Ctek battery tender 2 hours per day).
    Anyway, my trusted mechanic sent me this pic from the said gearbox software:
    Can someone confirm are these numbers correct for clutch driven +5k miles with really sensible usage?
    I've always tried to prolong the clutch life by never launching her, never reversing uphill, avoiding uphill starts, slowing down to the traffic lights with N selected after 3/4th gear, never driving during rush hour "start stop - start stop" kind of traffic etc. Maybe 30% of "SPORT" mode and 70% of "NORMAL" mode selected. I find it really confusing that the calculated clutch wear is so huge as 34%... :/
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,899
    Central NJ
    Dominick
    Hello and good day
    Just curious if you know if and when they will add ediff coverage to x431 ?
    Dominick
  5. sanfran
    sanfran Formula Junior
    523
    LA
    Oliver
    I bought the yellow EasyDiag but could not find a download link here.
    Where do I download the software?
    Thank you.
  6. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Those numbers are wrong....179.7mm isn’t possible. 17.97mm maybe......
    billy.gif likes this.
  7. sanfran
    523
    LA
    Oliver
    I got the EasyDiag. Can someone please PM me the link to the download?
  8. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Read post #289
  9. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,775
    Has anyone accepted the update? I can't remember if doing so will break the installation.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,899
    Central NJ
    Dominick
    Not sure what you mean.. ?
  11. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,775
    The app starts to prompt for an update once a new version is available. Until now I have ignored it. I wondered if anyone else has performed a successful upgrade of the version supplied by mechanicservice6 ?
  12. evilruss
    evilruss Karting
    Jan 27, 2015
    57
    Rockford
    I've been ignoring the prompt per MS6. I'm assuming it may break things, but was thinking if it did break then a clean reinstall using the files he provided may get it back to working.
    Sent from my SM-G930V using FerrariChat.com mobile app
  13. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,899
    Central NJ
    Dominick
    If this is a patched version .. I would not update it from native application..
    Is it looking to update firmware or actual brand ?
    Need to refer back to person who created patch to get new patched updated for brand
    I am afraid if you update firmware you may lock/block dongle
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,899
    Central NJ
    Dominick
    Not true.. if firmware is uodated with incorrect one you will lock/block dongle .. be careful
  15. evilruss
    evilruss Karting
    Jan 27, 2015
    57
    Rockford
    Ok good to know, then that would be a big concern. I have been unable to get a response from MS6 to my private messages for quite some time, but I believe I still have the most recent version for the Ferrari brand.
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,899
    Central NJ
    Dominick
    Give me a few screen prints of what is going on and also a screen print of the dongle info that has boot version, firmware etc
    Also let me know your eodbc version
    Delete/ block the last 5 digits of your dongle number for security when sending pics
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,899
    Central NJ
    Dominick
    Ferrari is still 10.26
  18. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    I updated the firmware on the dongle when I moved to 10.26. MS6 said accept the upgrade and install.
    Took a few seconds.....
  19. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,899
    Central NJ
    Dominick
    The firmware for the pro 3s is up to 11.65 now but but if you upgrade to the 11.65 of easydiag you will block your dongle
  20. Skidkid
    Skidkid F1 Veteran
    9,519
    Campbell, CA
    John Zornes
    What started as a nice thread about clutch replacement appears to have wandered off and become the "Pirated Software Thread". Seriously guys, if you use the software buy it then you can take the updates and all is good. You can afford the car but you can't afford to pay for the value of the software you are using. AND you complain that the software & tools are so expensive or not available. Could that be because most (like many of you) are stealing them an not paying for them?
    flash32 likes this.
  21. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,899
    Central NJ
    Dominick
    Although I agree that we should not be talking about pirated software I believe we should talk about the software that helps with clutch replacement... Some work better than others and some cost more than others
    Knowing the settings and the parameters and the shortcomings of the software would really help somebody replace the clutch
    Skidkid likes this.
  22. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,449
    On the Limit
    Dino
    That seems to be a lot of clutch wear for 5K miles. As for not being able to select a gear, the culprit may be the clutch position sensor. I had a similar problem a few years ago, but I did get a clutch position sensor code.
  23. Zed82
    Zed82 Formula Junior
    Sep 28, 2017
    513
    Sweden
    I got 2500 miles and only 6% wear on the clutch. Something is definitely wrong. Mine behaves perfectly and never skipped a beat with the new clutch.
  24. Skidkid
    Skidkid F1 Veteran
    9,519
    Campbell, CA
    John Zornes
    You make minor changes to the parameters and the calculated value is wrong. Maybe they weren't set right to begin with. Maybe they were changed by accident. Maybe you have that much wear. The only real way to know is inspection. Assuming you don't have a lot of clutch slip use the info as a baseline and drive the car. Check it again later and see if it is changing. That will tell you more than anything else.
  25. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    676
    Where do you guys recommend to get the
    LAUNCH Tech - EasyDiag 2.0 Plus
    It seems to be sold out everywhere I look? Any reliable source where I won't get a China-copycat?
