F1 Clutch Job | Page 16 | FerrariChat
F1 Clutch Job
Discussion in '360/430' started by Andrie, Jul 18, 2016.
  1. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    Does this work on an apple iPad??
  2. mechanicservice6
    71
    Our version of software is only for android. Only original software works on apple. Which software is not full pro and blocks the adapter so it cant be use with our pro version.
    Sent from my SM-G955U using Tapatalk
    grtoz likes this.
    billy.gif Formula Junior
    Mar 9, 2017
    259
    Finland
    From where can one buy just the software?
  4. mechanicservice6
    71
    Hello everyone I have been told about a new product from launch which if you do not already have a launch adapter then this would probably be best option so far as the only few left launch adapters are getting more expensive as they have been discontinued. Check out https://m.cnautotool.com/goods-5289-Launch+X431+Pro+Mini+Diagnostic+Tool+with+Bluetooth.html?gclid=Cj0KCQiAgebwBRDnARIsAE3eZjRaBYbq9MTRVa0PE-2TJhcC3GWdgNGhvGE6POWi0UYgheqwu21ZoEMaAma-EALw_wcB
    For those that already have launch adapters then you can contact me for software updates.
  5. Andrie
    Andrie Formula Junior
    Mar 6, 2015
    726
    Bay Area, CA
    Andrie Hartanto
    Hi mechanicservice, can you give me clarification? This tool already come with software for Ferrari but you have a better software? Or this software you have is for those that has android tablets?
  6. mechanicservice6
    71
    The x431 mini pro has the pro software also same software I have. Before the tool they had with this software cost around $1500 to 3k so we used the cheaper adapters which uses same firmware and it works just as good. Now since they figured out what is being done with the cheaper adapters, they discounted them and now they are around $400 if you can find it plus a tablet plus the software subscription. So for this reason if you do not have already a launch adapter then the best option is the mini pro for the price. I'd you already have the adapter then it would be cheaper to just upgrade software with me as it's cheaper.
  7. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    I have your software now from about two years ago. Do I need to update it or is it still good. What is in the update that I might need.Thanks
  8. mechanicservice6
    71
    It's all up to you... if the software works good for you then no need to upgrade. New updates have fixed issues and added better support for newer models. Ferrati version is at 10.85 currently. The software never expires so totally up to you.
  9. mechanicservice6
    71
  10. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    So if I am reading that correctly it fixes the problem of not being able to put a number after the decimal point when setting the pis? Thanks
  11. mechanicservice6
    71
    Correct
  12. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    I can confirm it does although I have to fiddle with it a few times before it will accept any number in the write field. I think this is user error but I can’t work out what I’m doing differently when it works....any advice appreciated!
  13. OffsetImage
    OffsetImage Rookie
    Apr 21, 2020
    24
    Spence Haldren
    I am looking to buy the software, is there a way to pay and have you send it through email?
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,900
    Central NJ
    Dominick
    If you don't have a single already .. it may just pay to buy an official product .. launch pro mini .. there is a group buy going on in Maserati forum
    Sent from my moto g(7) using Tapatalk
  15. OffsetImage
    OffsetImage Rookie
    Apr 21, 2020
    24
    Spence Haldren
    it wasn't that good of software? I just need it to do some basic stuff, reading clutch wear and read/clear codes. Wasn't worth it?
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,900
    Central NJ
    Dominick
    They have improved it alot ..depending on what year your car is/was ..pretty helpful for a f430 and up .. early 360 not so much
    If you just want to do reading and some resets look into a inexpensive ap200 autel
    OffsetImage and Apollo 11 like this.
  17. dz22
    dz22 Rookie
    I've looked online and cannot seem to find the mini at $400 - closer to $800 or so. Nor can I find the yellow dongle anymore. Does anyone know if this will work?
  18. jag-oo-r
    jag-oo-r Formula Junior
    424
    Is this still a thing?
  19. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    676
    Hi All,
    I have the EasyDiag 2.0 yellow cover adapter - does this still work in 2021?
