F1 Clutch Job | Page 2 | FerrariChat
F1 Clutch Job
Discussion in '360/430' started by Andrie, Jul 18, 2016.
  1. scuderia09
    scuderia09 Formula 3
    1,045
    #26 scuderia09, Oct 26, 2016
    Did you record the PIS reading before taking the clutch apart that a must and also it could only of been the E diffrental pressure and Switch that causing to go into N, 430 are well known for it, e diff and F1 system has to be bleed after a clutch replacment with a Scanner that's the only way , did anyone scan the 430 for codes before you replace the clutch ,
  2. scuderia09
    1,045
    Hope you had the special wrench to replace the throw out bearing and attachment bolts
  3. Andrie
    Andrie Formula Junior
    Mar 6, 2015
    724
    Bay Area, CA
    Andrie Hartanto
    14k miles. First clutch replacement. I bought it with 11k miles and the reading at that time was 80% used.
  4. Andrie
    Mar 6, 2015
    724
    Bay Area, CA
    Andrie Hartanto
    I have not replace the clutch. Car been sitting and I've been lazy. However I'm starting to get the itch to work on it and gathering info again. Good to know it requires special tool. I'm. It aware. Can you point me to what kind of special tool required?
  5. Ricambi America
    Sponsor Owner
    Andrie -
    The tool is shown here: 95973048 360 GEAR BOX WRENCH - Ricambi America, Inc.
    If you PM me, we have one in our loaner pool that I'd be happy to send out. The pins are something you probably should replace because their pretty cheap anyway: 201171 STUD FOR END OF STROKE - Ricambi America, Inc.
  6. Andrie
    Mar 6, 2015
    724
    Bay Area, CA
    Andrie Hartanto
    Daniel,
    thanks for the pointer. The tool looks similar to crowsfoot. Will a Crowsfoot not fit due to larger size?
  7. cclassics
    cclassics Rookie
    Jun 21, 2016
    38
    Langley
    Andrie-- sorry havent logged in for a while- saw your PM so will reply to update the thread
    with the ricambi kit i got the clutch wear sensor-
    before install i mic'd both discs as well as i could with them being attached to the PP. on race car clutches we mic for min TH (quartermaster etc) and thats how you know the life remaining- so when i saw the one that came out and the SD3 said its at 89% worn i measured it to compare to the new-
    the old clutch to me visually looked very good- so most likely the SD3 was reading correct but the clutch sensor was bad- but this isnt something that can be determined until its apart-
    after install with new clutch as i said prev it drove worse- it learned new clutch position with new sensor and it came in at 104% or something life left-
    the issue was the shift selector potentiometer. did a complete relearn procedure and it didnt correct the problem so ordered that part in and so far it seems ok- this was all completed towards end of last year and right now we have snow on the roads so it wont likely be driven again till april--
    at this time i think its fixed- will update once can be driven more-
    in the end i believe the clutch sensor and not the clutch itself- was only issue-
    the shift potentiomenter could have been on its way out but i was also told that the computer could possibly prevent shifts when the clutch wear sensor is getting towards 100%.. that i do not know if its true or not.. but re-re the trans likely sent a failing sensor to its demise..
  8. scuderia09
    1,045
    I don,t think your Auto Enginuity can't or ajust PIS reading
  9. tazandjan
    39,067
    Of course Autoenginuity can set PIS, run through the F1 self-test, bleed and do diagnostics for F1. I bought it for my techs and they have used it on several Ferraris with F1 to do just that.
    You are passing bad info for no good reason.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,705
    Central NJ
    Dominick
    For the benefit of Andrie and others, can those who purchased the a/e state where they got the best price / service from
    Sent from my Moto G (4) using Tapatalk
  11. tazandjan
    39,067
    Dominick- Directly from the guys who built it is how I bought it. AE's Ferrari/Maserati package also includes most European, Japanese, and American cars and all future updates. $3500, you provide the laptop. My guys have used it on Porsches and their own BMW, as well.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,705
    Central NJ
    Dominick
    Thanks 👍
  13. scuderia09
    1,045
    Not really, AE only limited to so much same line as the Texa does, maybe good for 360 and some older models and you really have to upgrade for about $5,500.00 for F430 and some 458 data that about as far as it goes and that won,t even give you any ECU upgrade flashing and it does half what the Leonardo can do,
  14. steelej
    steelej Formula Junior
    Jan 15, 2007
    433
    Have you used the AE software?
    John.
  15. scuderia09
    1,045
    I have did a lot of requirements about AE you really have to upgrade to get what you want and it not $3,500 for the whole package there little data you get of of it compare with the Leonardo
  16. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,861
    The Cold North
    Tom
    I have tried them all. So far nothing compaires to the Leo. I even worked with an SD3 and the Leo was much easier to use, and to be honest much better.
  17. tazandjan
    39,067
    scuderia09- As usual, you do not know what you are talking about. Stop spreading bad info.
    Yes, the factory tools or Leonardo are superior, but they also cost a lot more.
  18. scuderia09
    1,045
    #43 scuderia09, Mar 8, 2017
    Hey , just telling you my opinion on the software what it can or not do , but don't tell me I,am spreading bad info . For $3,500 what you expect your going to get it only a import package and don't try to say it does the same or better as factory or Leonardo system it doesn't compare , so stop spreading the bad info. how better the AE software is .
  19. scuderia09
    1,045
    I agree 100% I tried them all myself also.
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,705
    Central NJ
    Dominick
    #45 flash32, Mar 8, 2017
    Has anyone tried this unit
    Autel
    I have attached coverage as well as what tech support mentioned atop of the attached document - seems like you can get your hands on this for around 2700
    This is what is what tech support mentioned along with attachment for 430 Scuderia
    Please let me know what you guys think after looking at these documents
    I think it would suit OP for clutch job ???
    Brake Bleed Rear Right
    Brake Bleed Rear Left
    Brake Bleed Front Left
    Brake Bleed Front Right
    Steering Angle Calibration
    We Identifier Right-Hand
    We Identifier Left-Hand
    Rear We Identifier Right-Hand
    Rear We Identifier Left-Hand
    PIS Adaptation
    Self Learning
    Reset Wear Index
    Actuators Calibration
    Clutch Configuration
    Clutch Actuator Bleed
    Actuator Bleed Engagement And Selection
    PIS Adaptation
    Self Learning
    Reset Wear Index
    Upload/Download
    Km Updating
    Miles Updating
    Front Disc Wear Reset
    Rear Disc Wear Reset
  21. dapper
    dapper Formula Junior
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    I'm loving this thread..
    I've basically traded a 348 that gets lambasted about needing an engine out every few years for cambelt/tensioners change, for a 430 that has camchains, but unlike the 348 it needs engine/gearbox separation to get to the darned clutch (something that I could do on the 348 in less than an hour!).
    Oh and I need $k of elec equipment to do the job....brilliant.
    Gotta love Technology progress.
  22. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    At the risk of getting shot down, again... I am yet to find an aftermarket diagnostic that provides the functionality of the factory kit. To do the clutch job with later TCUs you really ought to be running the calibration using this cable: https://www.ricambiamerica.com/95979568-kisspoint-cable.html
    It is possible to manually set the PIS but it isn't the correct way. The Leonardo I was working with didn't have this functionality so, unless it's been updated in the last couple of months, the claims that it is as good as the factory kit are simply wrong.
    95viper likes this.
  23. scuderia09
    1,045
    It not the right way and why would you want to set the PIS manually and i don,t think it can be done , the ajustment higher and lower is very minimal , the Leonardo using only F1 ECU computer to set PIS and clutch reading
  24. tazandjan
    39,067
    scuderia09- You really should keep quiet about stuff you obviously do not understand. Of course you can set PIS manually unless you have an early 360, which only allows auto adjustment. There are dozens of threads on the subject. My 575M's PIS was set manually using Voicey's recommendations and AE software. 7.7 mm to be exact, quite a bit higher than the 360 PIS settings you normally see.
  25. Rifledriver
    36,825
    Adjustment higher and lower is not minimal at all. Manual PIS adjustment is a very valuable tool and if you had more than a small modicum of experience I would not be explaining that to you.
