355 - F1 Display and Warning Lights Flickering | FerrariChat
355 F1 Display and Warning Lights Flickering
Discussion in '348/355' started by Copperhed51, May 29, 2023.
  1. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    Time to address the latest issue with my car. When I got it, all was well except the F1 display was missing a segment, so I did a DIY repair on it with a new segment display. My soldering isn’t perfect, but I thought it went ok.
    Once I reinstalled the display, all of the segments would light up for a while and then it would seem to “settle” into working normally, displaying the correct gear number. Soon after, I noticed that when starting up the car, the circled warning lights/display would remain in a flickering illuminated state (all segments illuminated and flickering on the F1 display) for a little while and then after maybe 3-10 minutes, would return to what seemed to be normal operation.
    A few minutes after powering the gauges/display
    On initial power-up
    Today, I took the car for a drive and tried the Auto mode of the transmission. It worked as it’s supposed to, however, the AUTO light did not illuminate on the dash.
    I had the segment display replaced by Ricambi after my attempted DIY repair, but it behaves the same as it did after my attempt. It seems that I either damaged the display circuit board during my repair or there is some kind of connection that is glitching out after reinstalling the dash. I can’t find any good wiring diagrams for any of this and I’m not sure I’d understand where to begin troubleshooting if I did find a diagram.
    So, this is a semi-complicated problem that may require finding a rare/expensive replacement F1 display or maybe it can be repaired somehow. I’d appreciate any input to help me out with where to start.
    What is the common element with these specific lights/F1 display and why do they behave normally once warmed up? Even after shutting the car down, they behave normally at the next startup if everything remains warm or maybe hot. That is hopefully a helpful clue. I can do more troubleshooting if anybody has any ideas. Let’s hope we can solve this one. It’s not a huge deal, but I’d like to get it solved as it’s likely a self-induced error.
    By the way, the car was not running in the pictures, which is why there were other warning lights illuminated.
  2. Qavion
    Qavion F1 World Champ
    14,259
    Ian Riddell
    As it seems to be only F1-related lights flashing, it's probably not a general instrument power issue.
    If you look at the wiring diagram
    https://www.dropbox.com/t/ivA0BUDtL6LNoSys
    ... you can see that 12 volts goes to into the 12 pin plug on the F1 display on pin 1 (green/white "VB" wire).
    Is it possible that pin 1 was damaged on the connector?
    The car itself provides power to the individual lights (as far as I can see), but the instrument display unit provides 3 separate earths to turn on the individual warning lights.
  3. Qavion
    14,259
    Ian Riddell
  4. Ricambi America
    Sponsor Owner
    Please call me in the morning.
    When your original LED came in (before repair), I took photos of it, because it didn't look original to me. The brand of the chip wasn't the original Veglia version, or what we use as replacements. Had the whole chip been previously replaced? The solder blobs on your board looked ok, but the guy who does our repairs did note that the board looked 'scored'. (his words)
    Qavion likes this.
  5. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    #5 Copperhed51, May 29, 2023
    I’ll give you a call tomorrow. I’m definitely not blaming you guys because I replaced the segment display myself, which is when the problems began. My soldering skills/equipment leave something to be desired, so I very well may have screwed this up. Maybe your guy saw something specific that would be a clue as to what is going on. Weird that it seems to generally stabilize and work as designed once warmed up.
    @Qavion, I’ll start digging into things in the next couple of days. Appreciate the wiring diagram. Way more than I had to go on before.
  6. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    Looks like I’m focusing on this section of the diagram.
    I assume I fried something on the board, but I’m not sure which component that would be. Good chance I got sloppy with my soldering iron and either overheated a component or overheated some copper and “blew it out.” If I go by Occam’s razor, it’s safe to assume this is related to that F1 display PCB and something I did to it. Oops. I’ll likely end up paying a high price for my mistake, but I can deal with that. Would be cool to figure out what I did, though. If it’s a component on the board instead of the board itself, that would be fixable. I wonder if I mostly broke a copper connection on the board, but it expands enough to reconnect once things heat up. I dunno.
  7. Qavion
    14,259
    Ian Riddell
    Looking at the back of the board where the plug is located, it's difficult to say which pins are which...
    I've numbered them right to left (left to right on the plug side).
    1) is (possibly) lighting power (and general instrument power)
    2) is ignition power
    3) is earth
    4), 5) & 6) must be connected on the other side of the circuit board (under the plug)
    It's probably a LED module soldering issue, but it won't hurt to check the soldering on pins 1 ~3
    (EDIT: Sorry, crossposted)
    Copperhed51 likes this.
  8. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    Update on this: I’ve ordered a replacement factory F1 display as I think this is simply a case of me making a mistake in soldering. Maybe I blew out a diode somewhere? I don’t plan to do any troubleshooting of the problem unless the new display doesn’t not resolve the issue.
    Qavion likes this.
  9. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    Got the new display installed and all is well. No more flickering lights or odd behavior. Of course, the display I got has missing segments, so off to Ricambi it goes to get repaired correctly the first time. I’m sure somebody with time, patience, and decent electrical knowledge could fix the display that caused the flickering. That person isn’t me. I’ll stick to more mechanical repairs and leave the circuit board soldering to the experts. It is tempting to at least try to diagnose the bad board by testing and comparing each component with the known good board. Maybe someday.
    Philipnz and Qavion like this.
  10. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    Last update on this. I sent the “new” display to Ricambi to have a new segment display soldered on. Got it back, installed it, and everything works and looks like new. Not much left to do on the car other than enjoy it and service it regularly. I already have nearly everything I need for a thorough annual service when the time comes. I love this car! I’m oddly looking forward to the engine out in the next couple of years.
    Qavion likes this.
