F1 Fluid Leak (360) | Page 2 | FerrariChat
F1 Fluid Leak (360)
Discussion in 'Technical Q&A' started by voicey, Jul 24, 2010.
  1. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
    lastly im gonna start doing some things on my own, what tools do you recommend for working on the engine simple repairs that i can do.
  2. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
  3. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,440
    Santa Clarita, CA
    Too much F1 fluid shouldn't have any effect on being able to put it in first gear.
    That's a lot of fluid on the ground. Get your fluid level correct and see if that helps.
    Please use punctuation so it's easier for us to read, so we can help you.
  4. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
    Ok, thanks, i will get level correct again and see, what happens.
  5. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
    so when i put it f1 fluid in it starts to leak at bottom of car even when its not on, have you had this problem before
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
    matt
    I just want to make sure you follow the correct procedure you should turn the car key on without starting the car let the motor pressurize and then measure ... it''s going to be less than a quarter inch from the plate on the bottom of the reservoir... anything more will spill out after shutting car down ...if you don't have that much in there and it's still leaking that you definitely have the hose or something that is leaking ..or a cracked reservoir
    Sent from my moto g(7) using Tapatalk
  7. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,440
    Santa Clarita, CA
    If you're adding fluid and the pump is not running, and it's leaking onto the floor, you have a cracked reservoir, accumulator or hose. This is probably why it won't shift into first gear. F1 systems need pressure to operate. If there's a significant leak like you have, it won't build or hold pressure.
    Matt1984 and flash32 like this.
  8. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
    i see how would i know if it was a cracked resvoir. Im gonna take some pictures, is it possible to fix this myself if im willing to invest in tools? i find the mechanic i use takes really long and last time he leaked something on my hood and burnt through my clear coat, i wanted to start and argument but i knew he was gonna deny it, and i don't want to take to dealership because they will rape me. What do you think
  9. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
    i did when i turn key to right the f1 turns on for longer then normal time normally it makes normal sound then goes off this one goes on for longer period of time,
    im gonna take some more pictures thank you for your help
  10. TheRealFlyingBear
    Apr 27, 2020
    156
    SF Bay Area
    Ken
    Maybe you're checking the fluid level under the wrong conditions? As specified by the TSB, you're supposed to check with the engine off and cold. Open the driver door so the f1 pump primes itself... then check the fluid level.
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
    Check the solenoids, hoses , hose connections and accumulator.. look for leaks
    I would not keep key on too long since you may burn out pump from trying to keep pressure up
  12. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
    ok. will keep you posted. its definitely a leak.
  13. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
    i definitely have a leak, the question i have for you is it something i can do if I am diligent and get right tools, or is it really over my head, any feedback is appreciated.
  14. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,440
    Santa Clarita, CA
    I would think you could do it yourself. Lots of You Tube videos that may be of some help to you.
  15. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
    Looks like I’m probably gonna have to jack it up, do you have any jacks you recommend without spending too much and looks like I’m gonna ha e to invest in launch x431 do you have that
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
    #41 flash32, Jul 25, 2020
    Not sure the budget so here are a few ideas
    Rhino ramps
    Race Ramps
    Jackpoint jack stand system
    Quick jack
    Once you find out where the leak is exactly we can assess the amount of work / effort involved and then you can decide if you can handle
    Matt1984 likes this.
  17. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
    ok. sounds good.
  18. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
    do i need to equally jack both sides or just the side im working on should i buy two Jackpoint jack stand or will one be sufficient.
  19. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
    Get two if that is the way you decide . Also don't forget wheel chucks for opposite end
    Read up on undetray removal .. that also will play into decision
    The race ramps have a setup where the runway is removable and you end up with just tires on cribs ..
    The disadvantage of ramps and cribs is that not for any suspension or well work of course
    Here is s few searches in Google
    Type
    Undetray removal ferrari 360 ferrarichat
    jacking up a ferrari 360 ferrarichat
    Race Ramps ferrarichat
    Look at the posts that get returned from these 3 searches or any you decide to do and get familiar with jacking technics, ramps etc ..also get some tips and pics along the way
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
    No
    That is your power steering reservoir .. the fluid is similar to what you are using in the f1 system
  21. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
  22. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
    That’s what happened then I read manual wrong thinking that was what went in their, I put that in their that must have caused the problem with the leak, Man I’m a f**** idiot. So can use the same stuff that I use in f1 in their, obviously now I’m gonna have to flush out system. That’s what happened when I read manual it looked like that was what went there.
  23. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
    Yes it is basically a atf fluid ..dex III .. reddish in color
  24. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
    Yep so I’m gonna have to flush it out. That must have caused something to bust or break,Do you recommend getting the launchx431 to do the flush I guess from reading it can help detect lots of things.
