F1 Fluid Level in F430 | FerrariChat
Discussion in 'Technical Q&A' started by Joegnsx, Apr 27, 2014.
  1. Joegnsx
    Joegnsx Formula Junior Owner
    Dec 1, 2012
    958
    Valrico, FL & Franklin, NC
    Joe Gliksman
    So many posts about F1 fluids, but still difficult. No dipstick on mine-and I don't have one of those suction devices with a curved tube......but, I opened the reservoir and watched he level go down when the door was opened. Level dropped, but stopped dropping several seconds before the pump stopped. I made my own dipstick which showed 1or 2 mm of fluid above the bottom when the pump spooled up. I think this all means it's a little low?
    I've had a couple of slow down messages when hot, and hope topping it up fixes it.
    Anyone with experience please comment--thanks!
  2. Joegnsx
    Dec 1, 2012
    958
    Joe Gliksman
    No comments? A little surprise with all the talk and issues with F1--anyway I built my own (crude) level tool which works, and I replaced the fluid which was only a few mm low, but was thin compared to fresh Mobil 1--I noticed the pump "spooled up" much faster... So maybe an improvement?
  3. Skidkid
    Skidkid F1 Veteran Owner Rossa Subscribed
    Aug 25, 2005
    9,518
    Campbell, CA
    John Zornes
    I don't think that slow down has anything to do with the F1. My understanding is that is triggered by a cat temperature sensor. Usually a bad ECU for the cat but could be running too rich or other problems causing the cat to overheat.
