where is f1 fuse located on a 2000 360 coupe?
If you go to ferraridatabase.com, you can download a 360 workshop manual, coupe or spider, and it will show you very clearly. Should also be in the owners manual, which is available from the same site. The F1 pump relay often goes before the fuse does. It is behind the passenger seat behind the carpet on the rear firewall.
