F1 Gear box issue | FerrariChat
F1 Gear box issue
Discussion in '360/430' started by Jojorhalle, Dec 25, 2017.
  1. Jojorhalle
    Jojorhalle Rookie
    Jul 3, 2015
    18
    Hi All
    I have a 2007 F1 430 with a gear box issue- after driving for a while the RED gear box warning light came on with a loud warning sound, having trouble shifting into 3rd gear
    any idea what the issue can be ????
    bob
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    1st, how many miles on the clutch
    2nd miles on the car
    3rd what level in the f1 tank
  3. ///Art
    ///Art Karting
    215
    Check fluid first. If okay, it's possible there is air in the system. The one way valve on the Power unit sometimes malfunctions and allows backflow which traps air. Bleeding the e diff will temporarily fix the issue. Donyou have access to scanning the TCU and retrieving codes?
  4. Jojorhalle
    Jojorhalle Rookie
    Jul 3, 2015
    18
    Hi Art,
    Thaks for the response, I have approximately 7600 Miles and resentley serviced by Ferrari. I never checked the fluids, assumed when serviced it would have been checked, I guess not. Silly me !!!
    I will check.
  5. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,451
    On the Limit
    Dino
    Fluid is the first thing to check. You then need to read any codes. I had an odd shifting issue and when I read codes and checked clutch life, I had 95% clutch left and the code was for a clutch position sensor. I bought the sensor for $400 and took a couple of hours to install, and never had another issue.
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    You need about 3/4 inch of fluid in the tank with the system up to pressure
