News
F1 gearbox failure warning light
Discussion in '360/430' started by bumboola, Sep 29, 2004.
  1. bumboola
    bumboola Formula Junior
    Mar 7, 2003
    625
    I was out for a pretty long drive tonight and during the way back on the highway in 6th gear the F1 gearbox failure warning lit up with an audible alarm signal - the gearbox was working perfectly and I had no problems at all. After about 5 minutes it went away. Anybody had this happen to them? Anything to be concerned about?
  2. sparetireless
    sparetireless Formula 3
    1,392
    Should return to normal if you let it cool down, the beeping is clutch overheat alarm, maybe.
  3. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,238
    DC/LA/Paris/Haleiwa
    Mr.
    Where is the "F1 gearbox failure warning light"? If your talking about the transmission light, I don't think it would light up if the clutch is overheating. I get a beep. I'm not sure why a clutch would be overheating in 6th gear. Also, I think the beep for clutch overheating only sounds in first gear. Sounds like something you want to discuss with the dealer so you don't get stuck on the road.
  4. bumboola
    Mar 7, 2003
    625
    It's on the dash, it may be called something else on a 355.
    You're right, it was not the clutch overheating. It was not beeping, it was a solid audible alarm accompanied by the warning light. I had to pull over and check the owners manual to see what it was. The odd thing is that the gearbox worked perfectly before and after the warning and I was in 6th for several miles when it happened. I will ask the dealer about it, but sometimes I get more informative answers on FChat!
  5. albertl
    albertl Formula Junior
    Oct 23, 2002
    440
    Washington
    Albert
    Had this happen on my CS at 350 miles. The dealer put it under the SD2 and called FNA and they adjusted the clutch slippage and it went away. Evidently, the slip adjustment was off. I am now at 3,500 miles w/o incident. I would recommend you take it in.
  6. Rifledriver
    Rifledriver Two Time F1 World Champ
    26,949
    Austin TX
    The light should not come on if it is only a clutch overheat situation. If the light came on it should have recorded a fault in memory and can be read by the SD2. It should be investigated and if required corrected before it leaves you stranded. If the light and alarm come on while driving the sys has a failsafe mode to protect itself from damage. If the error or failure is serious enough it will stop the motor the next time you go below 5 or 10 mph and there you will sit. It happened to me on a freeway off ramp.
  7. damcgee
    damcgee Formula 3
    Feb 23, 2003
    1,864
    Mobile, AL
    DAYUM! And there was no OnStar to help you, either, eh?
  8. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    So. Cal and No. Utah
    Rick
    hmmmm. my guess is the F1 pump had a glitch or perhaps it is low on oil. check the F1 fluid reservoir and ask your dealer.
