F1 Gearbox Failure Warning Lt | Page 3 | FerrariChat
Discussion in '348/355' started by wiley355, Apr 4, 2017.
  1. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Ya but what else did you have to take off? cooler lines that run right beside the sensor, C/V boot cover and do you have cats on your car? Plus remember sometime's they can be real tight.
  2. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    True if you have a lift you don't have to take the wheel off.But most guys don't and i don't get under cars that are on jack stands.I said to take the wheel off for the guys that are doing it at home.
  3. WATSON
    23,972
    WI
    It's not a big deal. I did mine awhile back. Changed the gear box fluid while I was at it.
    Jack stands and in through the wheel well. Nothing more than a wrench. Hell, I don't even remember the size. Took like 15 minutes, and that included refilling my glass of wine.
  4. phrogs
    phrogs F1 Veteran
    7,365
    Kzoo Michigan
    I honestly don't remember but I didnt have to make a special tool to do it.
  5. Qavion
    Qavion F1 World Champ
    14,586
    Ian Riddell
    Steve, I thought you'd already sorted out your problems?
    That's the one under the gearbox. It determines the gearbox input shaft speed... probably has something to do with clutch engagement control. The relative speeds of various rotating parts affect the way the clutch engages. I recommend reading the manual... It's a little technical, but if you read it a few times, it starts to sink in :D
    This is the one which provides speed signals to the speedo, the engine ECU, the suspension ECU and the F1 ECU. It seems that a failure of this item would be easy to diagnose (unless it was very intermittent). With the potential to affect so many systems, however, I'd want to make sure it was in good shape. Of course, you would look for obvious faults with it first... contaminated connector plug, wiring insulation wearing away, etc. The wiring sheath contacts the oil lines, so you would want to make sure this was ok. I was surprised how grubby mine looked (despite the rest of the engine bay looking fairly pristine). It's not covered with an underbody panel and close to heat sources and also might get oil contamination from leaking cam seals.
  6. wiley355
    wiley355 Formula Junior
    542
    Vancouver, WA
    Wiley
    Air conditioning is weak, but I don't use it much up here in the NW. Heat worked fine. I checked the fuse (10A, #24 in the footwell fusebox) today and it's good.
    Will be proceeding with the speed sensor replacement and see if that fixes the problem - as soon as I get a round tuit.
    I really appreciate all of the guidance and information that I received on this thread.
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Let us know the outcome.
  8. Steve355F1
    Steve355F1 F1 World Champ
    Aug 26, 2011
    17,190
    Adelaide, South Aust
    Steve
    I have.
    However the clutch is pretty shot so I'm going to get that replaced in a month or so, and I figured while they are there for the sake of a few hundred $ it might be worth replacing these sensors too.
    Then virtually everything in the system will be new and will hopefully last another 18 years without any dramas. :)
    Thanks for the explanation of what the sensors do.
  9. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    #59 tr512, Apr 7, 2017
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Nice i figured something like that. Kinda like my O2 sensor remover socket.
  11. Qavion
    14,586
    Ian Riddell
    My 91 year old father just whipped up one for me... so no excuses for not making your own, guys... :D
    Just a thought though... I had a look at a 32mm "deep" socket today and I wouldn't be surprised if the whole plug and wiring wouldn't fold up and fit inside the socket. No cutting involved. I wasn't willing to pay to find out though :D
    ShineKen likes this.
  12. f355spider
    f355spider F1 World Champ
    18,056
    I don't recall requiring a socket to remove the speedo sensor. I just used an adjustable wrench IIRC. Or an open or closed end....
  13. Qavion
    14,586
    Ian Riddell
  14. wiley355
    542
    Vancouver, WA
    Wiley
    #64 wiley355, Apr 22, 2017
    It took awhile, but followed Myles Kitchens' procedure and am pleased to report that all was well on my 40 mile test drive this morning. Felt good to sweat, swear, and get my hands dirty - feeling more at one with the machine, and loving my car again :)
    And I am now the proud owner of a 32mm speedometer sensor removal socket, which we fabricated at a local shop.
    Learned alot from you guys.
  15. Qavion
    14,586
    Ian Riddell
    Congratulations. Glad to hear you survived.
    Another FChat win :D
    P.S. Can you confirm the part number of the new sensor?
  16. wiley355
    542
    Vancouver, WA
    Wiley
    From Ricambi: Table 31, Item 34, p/n 149095, Sensor/Speedo (Giallo-12V) @ $272.49
  17. ShineKen
    ShineKen Two Time F1 World Champ
    20,065
    Southern California
    Nostradamus
    So what’s the conclusion?
    Attack from top or bottom?
    Special/modified socket or wrench? I might consider a deep 32mm socket.
    Torque spec if any?
  18. f355spider
    18,056
    #68 f355spider, Jan 27, 2025
    I believe I used a 32mm open end wrench. I was lucky to pick up a huge selection of USAG wrenches for like $1 each at a Griots Garage annual "Garage Sale" event. I wasn't sure I would ever need wrenches that large, but for $1 each...what the heck?! I must have 25 of them in various sizes. That was a loooong time ago, but I believe I reached from above...but don't recall clearly.
    If you want to use them, I can mail them to you....but would want them back please.
    Unless you can find something similar at Harbor Freight.
    https://www.harborfreight.com/v-groove-metric-combination-wrench-set-14-piece-63063.html
  19. ShineKen
    20,065
    Southern California
    Nostradamus
    Just saw this. I appreciate the offer. Just bought a few 32mm sockets and going to modify. Should be quick.
    f355spider likes this.
  20. f355spider
    18,056
    Sounds good. It was the closed end wrench on the left I used. Probably the one and only time I ever used it.
