F1 gearbox stuck in neutral | FerrariChat
Discussion in '360/430' started by angelis, Aug 19, 2017.
  1. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    #1 angelis, Aug 19, 2017
    Whilst stopped at a traffic light, the 360 refused to change gear and remained in neutral. Ended up being transported home on the back of a truck.
    No warning lights.
    F1 pump is working when door is opened.
    No initial indication of what was going to happen.
    Did the electrical reset twice.
    Swapped fuses over.
    Car starts up fine and runs ok, just not changing gears.
    It has a CS TCU installed about 6 months ago. Clutch wear was around 29%
    Any other ideas on what the fault could be?
  2. LorenzoR
    LorenzoR F1 Rookie
    Since your saying your clutch wear is only 29% Ill throwout 2 possibilities..Clutch position sensor or Actuator.
  3. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,784
    Did you try auto or reverse?
    Neutral is one of the safety strategies to protect the box, but that is generally accompanied by a code that will trigger a warning light.
    Trying auto or reverse would quickly rule out something daft like the paddle assembly.
    To go any further really needs diagnosis.
    billy.gif Formula Junior
    Mar 9, 2017
    259
    Finland
    Will it engage gears when the engine is shut OFF but the ignition is on? IF so then its the clutch throw out bearing. Your symptoms are 100% like mine when the said throw out bearing went kaput earlier this year:
    IF engine was running, it wouldn't select any gear. If engine was shut OFF but ignition was ON, it selected any gear I wanted.
  5. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    Thanks.
    Tried reverse but didn't work.
    Didn't try Auto setting though.
    Thanks. Will give it a go.
  6. Skidkid
    Skidkid F1 Veteran
    9,629
    Campbell, CA
    John Zornes
    Another possibility is PIS is set too tight. There are so many possible causes. You need to get to an SD and someone who really knows these systems.
  7. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    Will hopefully have it picked up in a few days.
    Just wondering if there was an easy fix like a hidden fuse etc
    Mar 9, 2017
    259
    Finland
    And mine broke just like your "episode":
    I stopped at traffic lights, I always put it "N" when doing so. When lights changed I tried to select 1st gear but nothing was happening. When I shut the car OFF (but ignition ON) it would select any gear I requested, 1-2-3-4-5-6-N-R etc.
    IF its the throw out bearing then prepare for somewhat high bill as the gearbox needs to be removed in order to access it. Lets hope its something else!
  9. up4speed
    up4speed F1 Rookie
    3,703
    Long Island, NY
    Chris
    Maybe the brake light switch?
    If the computer doesn't realize that your foot is on the brake, it won't go into gear.
    I had some issues with the gearbox error light randomly lighting up when switching gears (no gear changing issues though) when I first bought the car. I changed the brake switch (~$45) and I never had an issue since.
  10. CarbonDan
    CarbonDan Karting
    191
    PNW
    If you shut it off, put it in say 2nd and started the car up, would it stay in gear and allow you to drive or kick it straight back to neutral as soon as the car started?
  11. nchhotu
    nchhotu Formula Junior
    319
    Roseville, Ca.
    Nick
    PIS settings incorrect. I had that issue intermittently with a CS TCU got clutch settings adjusted no problems.
  12. Stout
    Stout Formula Junior
    May 9, 2013
    259
    Helotes, TX
    Victor
    Brake light switch is not working properly.
  13. Stammler
    Stammler Rookie
    Aug 6, 2017
    11
    Sweden
    Same on friends 430.
    Cured after topping up hydraulic oil. Was lo level.
  14. 355fiorano
    355fiorano Formula Junior
    Oct 21, 2003
    782
    London
    Philip
    I had the same happen twice shortly after I bought it. It eventually got into first both times after some faffing about with the paddles, accelerator, ignition on/off. At about the same time the check engine light went on and as it was only a month since I bought it from the main dealer, they took it back and sent the ECU to be re-flashed at the factory. I haven't had this issue since but I now never switch into neutral when waiting or at traffic lights just in case ...
  15. Skidkid
    Skidkid F1 Veteran
    9,629
    Campbell, CA
    John Zornes
    So how do you think you would do that since the system automatically shift to N to start?
  16. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    360 all fixed. Turned out to be a very minor issue in the end.
    Picking it up tomorrow from Bell Classics and will post full details later.
    Thanks for all your help.
  17. up4speed
    up4speed F1 Rookie
    3,703
    Long Island, NY
    Chris
    Glad it was minor! Can't wait to hear the final outcome
  18. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    Just picked up the car from Bell Classics.
    The gearbox fault was due to a loose heatshield that shorted out the rear brake lights.
    If brake lights are blown, the F1 gearbox won't work!!
  19. Skidkid
    Skidkid F1 Veteran
    9,629
    Campbell, CA
    John Zornes
    That's correct.
  20. Gcolella
    Gcolella Rookie
    Jul 30, 2017
    22
    New york
    Good to know ! Sounds kinda strange though !
    So if one of my brake lights burn out the f1 trans won't work?
  21. Ron328
    Ron328 F1 Rookie
    2,628
    Willamette Valley, Oregon
    Ron
    Great to hear! That's a weird kind of connection (but what the hell do I know...).
  22. mello
    mello F1 Veteran
    5,519
    CA Bay Area
    Steve
    Yup. That's why I converted to LEDs and carry spare LED bulbs and a new brake switch in the frunk. I don't want to get stranded somewhere out on a rural road without cell signal. I also practice how to change out the bulb by feel in case it happens at night time. :)
