F1 gearbox wont select gear when stationary | Page 2 | FerrariChat
Discussion in '360/430' started by billy.gif, Apr 15, 2017.
    billy.gif Formula Junior
    Mar 9, 2017
    259
    Finland
    Left picture on the 2nd row. Pieces came from the clutch plate itself, the metal part of it. Next to one of the five springs.
    Is that normal?
  2. LorenzoR
    LorenzoR F1 Rookie
    ok i see it now. i never seen that before but others may have...
  3. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    Some set comes with the TOB and some sets don't. Just see the list parts included in the kit.
    Whatever your choice is make sure they properly torque everything including the TOB. Mine broke due to bad torque setting (from the previous owner's shop). It was just a little over a year after replacement when it broke.
  4. honda.vfr
    honda.vfr Karting
    Jun 22, 2012
    134
    Ostrava, CZ (EU)
    Milan Pukl
    I have seen and replaced many clutches (but not On Ferraris), that were broken even more than yours. Usually the broken metal parts fall into the pressure disc central spring and then do not let the clutch to fully disengage... Try Eurospares, geographically they are nearest to you and will have the clutch set in stock for sure ;)
    Mar 9, 2017
    259
    Finland
    Thanks for the hint of Eurospares! :)
  6. Mikael-F360
    Mikael-F360 Formula Junior
    Apr 3, 2017
    754
    Finland
    Mikael E.
    Please keep us posted; is the car now OK and the clutch now working normally?
  7. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,770
    England
    Mark
    Worth noting that your clutch was absolutely knackered anyway, so in effect this incident was not a waste of money nor a good clutch. Ensure the flywheel is checked before a new clutch is fitted, and the TCU setup is OK once you have the car back i.e. no grabbing or excessive slipping of the clutch.
    P.S. Your release bearing was leaking. Replace it. Likely causing the clutch to drag.
    Mar 9, 2017
    259
    Finland
    Wow, you can tell this from pictures?
