F1 has mind of its own | FerrariChat
Discussion in '360/430' started by Joe Larussa, Jun 24, 2022.
  1. Joe Larussa
    Joe Larussa Rookie
    Jun 8, 2022
    7
    Joe Larussa
    I have a new to me 2006 F430. Intermittently the F1 light comes on then it switches to auto mode by itself. Thoughts? Thanks for your time!!
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,954
    Isle of man- uk
    When you start it up in Neutral, it will default to auto mode. Once you select 1st and drive off it will be in auto- if you want to use manual you need to press the console button and the auto indication under the gear number will go out.
    Are you getting something different.
    flash32 likes this.
  3. Joe Larussa
    Joe Larussa Rookie
    Jun 8, 2022
    7
    Joe Larussa
    I am getting something a little different. Maybe I’m not doing it correctly, but I typically start it in neutral, then select first gear and it seems to already be in manual mode. Drove this way for roughly 20 minutes, then the F1 light would beep, then the auto light came on and started sifting on its own.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,954
    Isle of man- uk
    It will start up in neutral and auto mode- you select 1st gear to move off and if you keep your hands off the F1 gear levers it will change up and down by itself. If you want to use the levers you need to select manual by pressing the button, then use the levers.
    If you do not press the button but use the levers, you are over riding the auto select system and this might be why you are getting a bleep. The gearbox will let you use the levers as manual but if you have auto selected you are confusing the system. Decide to use one or the other and see if that cures things
    Joe Larussa and Qavion like this.
  5. Joe Larussa
    Joe Larussa Rookie
    Jun 8, 2022
    7
    Joe Larussa
    I start the car in neutral, back out of the garage then select 1st. I never select auto. Haven’t changed anything and this past week it’s been perfect. Go figure ‍♂️
    Sergio Tavares likes this.
  6. tazandjan
    39,162
    They are female and just want to make sure you pay them attention.
    VAF84 and Sergio Tavares like this.
  7. Joe Larussa
    Joe Larussa Rookie
    Jun 8, 2022
    7
    Joe Larussa
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,954
    Isle of man- uk
    When you select first, it will be in auto by default, it will run in auto mode until you change it to manual using the button on the central consol
  9. Joe Larussa
    Joe Larussa Rookie
    Jun 8, 2022
    7
    Joe Larussa
    So this F1 transmission thing is happening more often. It is basically shifting from manual to automatic and back again with no help from me. Today I tried to put it in neutral before starting and it would not do it. I started it in 1st gear and it would beep at me and shift between auto and manual mode. Hitting the auto button did nothing. Went for a drive and it kept doing it. It settled down after five miles but came back again. Let me know your thoughts and if I should bring it in. Is there a relay or something electrical that might be intermittently failing? ‍♂️
  10. Love154
    Love154 Rookie
    Oct 16, 2021
    11
    What area are you in
  11. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,948
    The Cold North
    Tom
    Your auto mode switch is probably faulty. Have the car scanned first..but I'll bet that is your issue.
    efg2014 and Sergio Tavares like this.
  12. LorenzoR
    LorenzoR F1 Rookie
    I have one for sale in the classifieds if needed.
    Joe Larussa likes this.
  13. Joe Larussa
    Joe Larussa Rookie
    Jun 8, 2022
    7
    Joe Larussa
    It’s in the shop now. They’re thinking it may be the TCU but not totally convinced yet.
  14. Joe Larussa
    Joe Larussa Rookie
    Jun 8, 2022
    7
    Joe Larussa
    Just a follow up. The issue was a bad paddle assembly on the downshift side. Go figure!
  15. craze
    craze Formula 3
    Mar 5, 2021
    1,165
    Melbourne
    Michael
    Interesting
  16. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,304
    Sergio Tavares
    Please to not be so violent on the downshift paddle, it will not make it shift like the Scuderia
  17. efg2014
    efg2014 Formula Junior
    Sep 14, 2014
    657
    Northern California
    When I was new to my 2006 F430 years back, it was automatically shifting when I was using the paddle and it confused me. Turned out I had hit the Auto button at some point such that the car was automatic. Don't believe you have the same issue but thought I would share. Also I have found the F1 system to be very reliable.
  18. tbakowsky
    Sep 18, 2002
    19,948
    The Cold North
    Tom
    It is very reliable. It's the inexperienced techs who are working on them that are causing most of the unneeded expensive repairs.
