F1 Hydraulic System | FerrariChat
F1 Hydraulic System
Discussion in '360/430' started by English Rebel, Sep 1, 2013.
  1. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    I have the F1 360. I know that when you open the drivers door the hydraulic pump will run so it's ready for when you start up. Mine runs for about 6 or 7 seconds. However if I close the door and open it again say 30 seconds later the pump runs again for about 2 seconds. I would have thought that once the pump had achieved pressure to actuate the pressure switch the system would remain at pressure for longer. In looking at the diagram the configuration of the pump is not what I'm used to (no suction and discharge -- just a pressure outlet) so how does the pressure bleed down? Maybe someone with intimate knowledge could explain how the system works as I'm used to hydraulic systems that remain pressurized until used.
    Alan
  2. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,162
    Alan- When you open the door, there is a signal sent to the F1 pump to turn on and pressurize the system. When you do it the first time, it takes a while for the system to come up to pressure and then tell the pump to turn off. When you do it the second time, the same signal is sent to start the pump, the system then checks the pressure and shuts the pump down very quickly. So the sequence is turn on pump, monitor pressure, turn pump off when pressure is normal. So you will get a second or two of pump actuation before the system realizes pressure is already up.
  3. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    668
    I'm going through the F1 system to solve a separate issue...
    Keep in mind that if you notice your F1 priming time (the first time the pump runs when opening the door) get longer it may mean an issue with the system so be on the lookout. With these cars unfortunately it's 'when' rather than 'if' it happens.
  4. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Yes but why does the system loose pressure over such a short time?
    Alan
  5. mello
    mello F1 Veteran Silver Subscribed
    Jul 12, 2013
    5,488
    CA Bay Area
    Steve
    Looking at the diagram, could component #25 and/or 32 possibly be a check valve? I'm just guessing at this point.
  6. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    25 is a union and 32 is the pressure sensor. I looked at the system at the clutch and gearbox and don't see a check valve.
    Alan
  7. vrsurgeon
    vrsurgeon F1 World Champ Silver Subscribed
    Dec 13, 2009
    16,523
    Charleston, SC
    Curt
    What I was thinking was that the unit 1, may have an integrated check valve with the pressure reservoir in it (tht bulb on it.. Prob filled with gas to maintain pressure like in home water systems). I was also thinking the pump may have some retrograde fluid movement out of it... Or that the system is just designed to pressurize the system by running the pump, even though it is at pressure... With excess being bled back to the reservoir. We just don't see the pressure relief valve..
  8. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Curt
    The pressure relief valve may be on item I -- the complete hydraulic actuator (at $17,102 -- yikes). It always amazes me at how much parts for a Ferrari cost. I mean $17k for a simple valve body.
    Alan
  9. DanNE
    Jun 7, 2013
    668
    If you ever need that fixed, send it for a rebuild, it's around $1.5K to rebuild it.
    I've also found some of the $2.7K sensors that are on the actuator (there are two) also exist on other cars for about $100 each! Talk about Ferrari parts mark-up. I'd love to be in that business...
  10. Stout
    Stout Formula Junior
    May 9, 2013
    259
    Helotes, TX
    Victor
    Tell me more about the sensors.
  11. tomoshea
    tomoshea Formula Junior
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    Yes very interesed......all good for the community at large.
  12. tazandjan
    39,162
    Alan- No, it does not lose pressure that fast. It just takes the system a finite amount of time to determine it does not need additional pressure and shut down the pump.
  13. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Terry
    I was just cleaning my seats and the first time I opened the door the pump ran for about 8-10 seconds. While I was cleaning the interior light went out (not sure how long that took) so I closed the door and then re-opened it. The pump ran for 2 seconds.
    Normal?
    Alan
  14. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    seems normal to me, mine does that also.
  15. rustybits
    rustybits F1 Rookie Professional Ferrari Technician
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Item #32 is the pressure switch. Item #1 is the accumulator. The pressure relief valve is built into the valve body and is not available separately, nor is it removable. They do not fail. The OP's car sounds normal in operation. Many cars are being driven around with marginal systems that cause poor selection due to small leaks or other issues that don't ever get addressed. It's why the F1 system has a bad reputation according to some. In truth a well maintained system rarely goes wrong. Typically, cars will still continue to function, even when you pull them apart and you find stuff like this:
  16. mello
    Jul 12, 2013
    5,488
    CA Bay Area
    Steve
    What's the name of the bad part in the picture?
  17. tazandjan
    39,162
  18. Macshop6700
    Macshop6700 Rookie
    Feb 8, 2024
    12
    Zaz
    I just replaced the thrust bearing and the f1 pump. Now the gear indicator flashes and won't pass 2nd gear with transmission light on. Did it happen to you?
