F1 Issue? | FerrariChat
F1 Issue?
Discussion in '360/430' started by rgavitt01, Aug 14, 2007.
  1. rgavitt01
    rgavitt01 Rookie
    Apr 8, 2007
    1
    Flower Mound Yexas
    Robert Gavitt
    I have a 01 360 with an F1 (20KMiles) and when I am out running around, randomly when I get back in the car to start, the F1 is in 1st and pullin gback on both won;t immediately return it to neutral. If I pull the upshift and then downshift it will then go to neutral. I have checked fluid level, its fine and it shifts fine just this random issue. Ideas?
    Thanks,
    Robert
  2. marky1
    marky1 Formula 3
    1,130
    Mark
    When you pull both back, try planting your foot on the brake a bit harder, might work. Sorry can't help beyond that.
  3. james patterson
    james patterson Formula Junior
    Dec 8, 2003
    417
    Dallas Texas
    James Patterson
    Are you setting the emergency brake when you leave it in gear? Also are you upshifting then downshifting then pulling both to get it in neutral or is it going to neutral on the downshift?
  4. Uomo360F1
    Uomo360F1 Formula Junior
    Aug 24, 2007
    488
    It looks like the tranny sensor is bad. This happened to my friend's '04 360, until he replaced the black electronic sensor located on the transmission housing, under the engine. Remove the bottom skid panel.
  5. racerdj
    racerdj F1 Veteran
    Jan 19, 2003
    6,952
    Indianapolis
    DJS
    Sorry for the problem. I never had the issue you described.
