F1 leak | FerrariChat
F1 leak
Discussion in 'Technical Q&A' started by Aj360, Feb 25, 2020.
  1. Aj360
    Aj360 Karting
    Dec 28, 2018
    149
    A j -aj
    So my 360 is getting the 430 muffler on we just waiting on some brackets from Ferrari to come in ... my cars been sitting there for bout a week now “ it always had a slight f1 line leak which was going to be fixed when it goes back in for the cs tcu upgrade .. I check the car everyday .. went past as usual bout 6:30pm all good .. went to go to work bout 12:30am ..had a decent trail of f1 fluid on the ground Was like wtf is going on checked the f1 fluid was full .. f1 pump primed up for bout 10-12 seconds sounded healthy .. selected gears like a champ no dramas .. I can’t work out how it’s just dumped it at random car hasn’t been started or driven .. it’s been isolated for a week there’s no muffler on it very strange anyone got any idea about this
    View attachment 8171630 View attachment 7570123 View attachment 5386812 View attachment 8171630 View attachment 7570123 View attachment 5386812
  2. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    It is possible that the accumulator finally unloaded and over flowed the reservoir. as soon as you open the door and prime the pump, the level drops. You can loosen the bleed valve and and dump the accumulator then check the fluid to make sure it is not too full. That would be my guess going by your description.
    The attached pictures didn't come up for me, so I took a shot in the dark.
  3. Aj360
    Aj360 Karting
    Dec 28, 2018
    149
    A j -aj
    Man sounds like that would be close cause the f1 fluid was topped up .. I haven’t driven it much cause it’s been off the road getting work .. I was just like what the hell .. will upload a pic for some reason here don’t work to good with pics
  4. Aj360
    Aj360 Karting
    Dec 28, 2018
    149
    A j -aj
    That’s the trail lol was decent but wasn’t much when I wiped it up ..
  5. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Looks like overflow when system depressurises..... have you checked the level following the proper procedure or just filled it on the dipstick?
    Aj360 likes this.
  6. Aj360
    Aj360 Karting
    Dec 28, 2018
    149
    A j -aj
    Hey man the cars just sitting there cause we are doing some work on it hasn’t even been started has been isolated for while it just happen out of no where .. I was thinking the same as you must of just let go of some fluid was topped up month back .. just couldn’t work out how it did it with no power
