F1 light | FerrariChat
F1 light
Discussion in '360/430' started by suecom, Nov 27, 2016.
  1. suecom
    suecom Rookie
    Dec 23, 2015
    7
    Switzerland
    Allister
    I intermittently get a single, or three consecutive beeps and flashing red gearbox oil light. At the same time, the gearbox switches to 'auto', but seems to function fine. I can switch the box back to manual, but it will re-occur. Then sometime it won't happen for 100km?
    I checked the F1 fluid levels (overfilled it a little at first - after cleaning I didn't see this problem for a while), and the pump seems to prime (on opening the door) within ~5 seconds.
    Any ideas where I should start? No CEL/fault codes on the engine ECUs.
  2. vrsurgeon
    vrsurgeon F1 World Champ
    16,540
    Charleston, SC
    Curt
    Gots to scan it with an SD2 scanner or Leonardo. It helps to know what the car thinks is going wrong.
  3. Skidkid
    Skidkid F1 Veteran
    9,531
    Campbell, CA
    John Zornes
    AND, it depends on when you get this. The 360 F1 can take some extra time to prime in colder weather. That 'low pressure' can cause a warning, even if brief.
    I guess that means exactly what Curt said. Get it scanned because there isn't enough information here to diagnose.
