F1 Light | FerrariChat
F1 Light
Discussion in '348/355' started by Roth, Jan 21, 2017.
  1. Roth
    Roth Formula Junior
    Apr 1, 2016
    433
    Pepsi Generation
    Gentlemen, on the other thread many of you mentioned the F1 light blinking for minutes sometimes more. I haven't experience any blinking F1 light. So this morning I went to start the car paying close attention and again no blinking light of any kind. However, there was a high pitch noise from the engine bay that lasts about a minute or so and gone. I think the high pitch noise was from the pump motor building up hydraulic pressure. As far as the light, could it be a different model year thing? Any thought? May 1999 F1
    In the past I never had to wait for warm up. The car goes into gear right away.
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Check the bulb. Every F1 has it. You can select N or gears until the light goes off which means the system has built enough pressure.
  3. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Could the high pitch noise be the emission secondary air pump?
  4. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yes, but the F1 pump is louder.
  5. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    No it's not.If your car is running you should not hear your F1 pump over your secondary air pump when cold on start up.If you do then you have a problem.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I disagree, Mike. My car has no F1 issues at all.
    http://youtu.be/CWMFg_H1OwM
    I should also state I typically start the car after the F1 system is primed.
  7. Roth
    Roth Formula Junior
    Apr 1, 2016
    433
    Pepsi Generation
    I should state, the high pitch noise only audible at start up and last less than a minute. Regardless, the car goes into gear even when the noise is present.
    With the key turned to the second position, all the lights pop up and disappear except the F1. It doesn't come on at all.
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    As I stated, the system will reach pressure before the pump stops. Once primed, short stops require no or very short prime times.
  9. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Read what i said ..if the car is started cold you should not hear your F1 pump over the air pump.
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Mike - if you watch my video you will see my car is too loud to hear ethier with the car started
  11. Steve355F1
    Steve355F1 F1 World Champ
    Aug 26, 2011
    17,175
    Adelaide, South Aust
    Steve
    My understanding is that you shouldn't start the car until the pump has stopped.
    If you park your car in 1st - like you're supposed to - it means once the pump stops you can put it in neutral and start the car.
    In my car the light stops flashing quite some time before the pump stops.
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Steve, if the car is in N, you can start right away. I keep mine in N in my garage but keep in 1st when out.
    Gear changes are allowed once the light goes off even if pump is still running. When light is flashing, you cannot select gears or N even if you try.
  13. Steve355F1
    Aug 26, 2011
    17,175
    Steve
    That's true Dave, but I'm curious why you would park the car in neutral when Ferrari specifically recommend against doing it?
    There's a reason you get a loud, long "beep" in protest when you do this.
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Steve, I park in N in my garage as it's flat, my hand brake works perfectly and N is required to start the car.
  15. Steve355F1
    Aug 26, 2011
    17,175
    Steve
    Fair enough. Just curious.
    You must be like Batman and have to leave the garage in an enormous hurry every day.
    :D
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,019
    Indio Ca/ Alberta
    Grant
    Also Steve some people have had problems parking in gear. You are correct though it beeps , but my guess it's a safety thing kinda like bonnet or door adjar
  17. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Haha! Well, I only save 1-2 seconds this way :)
    Just a habit I guess as sometimes I will push my car forward or back a bit if working on it so keeping it in N helps for that ;)
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,019
    Indio Ca/ Alberta
    Grant
    Or when pulling tires to get at something it's easier to rotate so the pin is centered up top
  19. Roth
    Roth Formula Junior
    Apr 1, 2016
    433
    Pepsi Generation
    This probably a dumb question. Where is the F1 light, between the tach and the speedo above the temperature gage?
  20. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    bottom left side
  21. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    If you watch the video I posted, you will see it.
  22. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    #22 phrogs, Jan 23, 2017
  23. Roth
    Roth Formula Junior
    Apr 1, 2016
    433
    Pepsi Generation
    Thanks guys! So that thing with the stick is the F1 light. No wonder I couldn't find it in the manual.
    I guess if you drive your car daily, priming before start up is managable For us "posers" who drive it maybe once a month priming with engine off might just kill the battery.
  24. WATSON
    23,847
    WI
    No it's not.
  25. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Not really, not much time for the pump to prime ;)
