F1 Module? | FerrariChat
F1 Module?
Discussion in '360/430' started by felo360, Dec 18, 2010.
  1. felo360
    felo360 Rookie
    Nov 2, 2010
    43
  2. djastral69
    djastral69 Formula 3
    1,896
    Fl
    David
    I have put in a Stradale TCU in my 2001 Spider I had and then input via SD2 your clutch percentage and you're good to go! You can get the Stradale TCU from Daniel at Ricambi America.
    You will see an immediate difference between your 2000 and this TCU for sure.
  3. tazandjan
    39,174
    There are threads on Formula Dynamics here and you can easily search for them. At least one FChatter tried it and it worked great for him. Plus it is relatively easy to unplug if you want to go back to OEM. Cannot do that if you have your F1 ECU/TCU reflashed.
    http://www.ferrarichat.com/forum/showthread.php?t=289323&highlight=improved+F1+shifting
    Another alternative is to change out your TCU for a Challenge Stradale version. That has been doen by quite a few FChatters with good results. The 058 software release for early 360s was replaced by 158 in the 2003 timeframe and the CS release was 168, so quite a few updates were done during the 360's production life.
    Taz
    Terry Phillips
  4. duskybird
    duskybird F1 World Champ
    12,618
    29 Electoral Votes
    Bill B.
    Do a search. There has been a couple of discussions on this with some pretty positive results.
