F1 NOISE WHILE SHIFTING | FerrariChat
Discussion in 'Technical Q&A' started by pullover, Mar 13, 2010.
  1. pullover
    pullover Rookie
    Nov 17, 2006
    32
    Jackson, Wyoming
    Ted Edwards
    WHILE UP SHIFTING IN MY 07 430 COUPE A STRANGE RELEASE OF AIR CAN BE HEARD FROM ENGINE BAY, LIKE THE SUDDEN RELEASE OF A WASTE GATE. THE NOISE NOT AUDIBLE ON DOWNSHIFT. THE HARDER YOU PUSH IT THE MORE NOTICEABLE. THIS WAS CHECKED OUT BY WELL RESPECTED LOCAL AUTH. FERRARI DLR . MECH. HE HAS NEVER HEARD THE NOISE AND UNSURE OF ITS ORIGIN. ANY THOUGHTS BY OUR SUPERTECHS ?
  2. fastback33
    fastback33 Formula 3
    Mar 8, 2004
    1,851
    YES, I BELIEVE YOUR CAPS LOCK BUTTON IS STUCK.
    Check plastic lining around intake or intake itself. Sounds like some kind of vacuum leak or it wouldn't make a swooshing sound.
  3. pullover
    pullover Rookie
    Nov 17, 2006
    32
    Jackson, Wyoming
    Ted Edwards
    F OF D RULED OUT ANY VACUUM LEAKS. THAT HOWEVER WAS MY FIRST THOUGHT. ANY OTHER THOUGHTS?
    THANKS FOR YOUR REPLY
  4. tazandjan
    39,315
    Ted- What FB 33 was telling you was to deselect your stinking Caps Lock button. After everybody's internet ears stop ringing, hopefully one of the pros can help you.
    Last time I looked, there were no pneumatics involved in the electro-hydraulic F1 shifting system.
    Did you recently change your exhaust system to one with lower back pressure? If so, the noises you hear are normal.
    Taz
    Terry Phillips
  5. pullover
    pullover Rookie
    Nov 17, 2006
    32
    Jackson, Wyoming
    Ted Edwards
    HI TERRY,
    EXHAUST SYSTEM AND ENTIRE CAR BONE STOCK. I AM HOPING SOME PROS WITH GOOD IDEAS CHIME IN.
    AGAIN, VERY HIGHLY RESPECTED F-CAR TEC AT FofD RAN INTO DEAD END, SO YES, I NEED SOME PROS OR 430 OWNERS WITH SAME PROBLEM TO JUMP IN.
    THANKS TERRY
  6. BLAMPEE
    BLAMPEE Man Card Status: Never Issued
    LoL...I don't think he got the CAPS comment.
    Funny. :D
  7. pullover
    pullover Rookie
    Nov 17, 2006
    32
    Jackson, Wyoming
    Ted Edwards
    Just looking for a REAL ANSWER for a REAL problem. He got it, no help here.
    THANKS
  8. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    It used to be called SHOUTING.
    So QUIT SHOUTING.
    Actually, I have the answer to source of this particular noise but need a week or two to drive the car around to be certain.
  9. away
    away Formula Junior
    Aug 5, 2004
    635
    Lansdale, PA
    Andrew
    I'd be very curious to hear the answer to this as well. I've been experiencing a similiar noise in my 360. (thread regarding it in the 360/430 section)
    Does it happen most frequently after shifting (up or down)? Occassionally it will happen when stationary, but almost always about 3-5 seconds after a shift. So I have to guess it's F1 system related. It almost sounds like a faint honking noise, yea?
    Additionally, it only occurs when the car is hot. I've driven 40 miles in the car from cold without lots of shifting and it won't make the noise.
  10. pullover
    pullover Rookie
    Nov 17, 2006
    32
    Jackson, Wyoming
    Ted Edwards
    I notice air release noise immediately after downshift only. it is a gush of air only, not a HONK. Sounds like different noise.
    ted
  11. away
    away Formula Junior
    Aug 5, 2004
    635
    Lansdale, PA
    Andrew
    Could that just be the intake noise from the rev matching of the downshift? Basically just an induction sound as the motor is rev'd slightly.
  12. BubblesQuah
    BubblesQuah F1 World Champ
    13,248
    Charlotte
    Anyone else confused? Upshift or downshift?
  13. pullover
    pullover Rookie
    Nov 17, 2006
    32
    Jackson, Wyoming
    Ted Edwards
    Sorry, my error,noise on upshift only.
    thanks,ted
