F1 oil | FerrariChat
F1 oil
Discussion in 'Technical Q&A' started by Gary48, May 1, 2007.
  1. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    What viscosity oil is formula 1 running? I have heard conflicting stories, one stated 0W10 and another straight 70W. Whats the current thinking and usage?
  2. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Ive heard conflicting stories as well, but one telling one is an article about a year ago in Cavallino regarding the Ferrari Clienti program where wealthy dudes and dudettes can buy rides in previous years F1 cars. In the article it stated that MS car and others being used that day were hooked up to a auxillary oil heating unit and the cars oil was heated and circulated before starting as the oil was to thick. That was only a year ago, and I believe they are still running high vis oil.
    But from a Shell website:
    "Secrecy and technology go hand-in-hand in F1. Shell and Ferrari decline to reveal certain facts such as how much oil the car carries, oil viscosity or fuel mileage, never mind more specific technical information".
  3. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Much has been discussed on the bennefits of thinner oils, more horsepower, less drag, cooler running and of course better milage but am I right in assuming that in the very high stress and high rpm environment of F1 that film strength is more highly prized than some of the other attributes of thinner oil?
  4. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    But even 70 weight oil can be thin at higher temps.
  5. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I believe that its next year they are talking of going to a three race per engine rule, and possibly four races per gearbox. Oil is going to play a very important part in extending engine life. Ive tried doing searches several times and I come up with nothing but Amzoil, Red Line, Mobil1, and Royal Purple websites one after the other. Mums the word I guess.
  6. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    It was just last issue of Race Car Engineering where the issue of V-8
    F-1 engines having durability issues and that advances in lubricants were a prime focus. It seems that engine failure is no. two reason for not finishing, collisions are no. one. There is probably zero chance there will be any revelation of oil advances.
  7. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,424
    CT
    Jay
    ok I'll agree that oil is still important...but I think it was Rifledriver who pointed out in an oil thread that you rarely see oiled parts failing due to frictional issues. Most engine failures are stress-fatigue issues or something similar, not so much from cam lobes wearing out. Oil does contribute to stress fatigue failures when you consider it reduces frictional heat, and heat reduces fatigue life of metals. I think F1 actually has a good oiling situation compared to street cars because it's predictable - they know just how hot those things run, and it's fairly constant as compared to us fools running engines in a wide range of temps.
  8. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Very good points and in the past this was especially true, now however rule changes have minimised mechanical limits in regards to known and tested stress values, i.e. 19,000 rpm rev limits. F1 has always lightened componants to the point of failure and often left little in regards to material strength safety margins taking it to the ragged edge so to speak.
    It is now said that everyone this season will be in the 750 bhp range, well within known component failure. With this in mind lubricant developement will be a key area now that the mechanical specification is frozen, but, as they report , only marginal gains are to be had there!
    If any gains can be made no matter how insignificant, rest assured millions will be spent to fully explore tenths of a second per lap and in the process a gain in mechanical efficiency and durability.
    I would still like to be a little mouse and know what compounds of lubrication exist in these ultimate formulations, or are we all fooling ourselves and these formulations are near what we can access at our local auto shop?
  9. Rifledriver
    36,768
    If you are ever involved with a race car that is sponsored by an oil company you will recieve bottles that look just like the ones at Pep Boys but you are told not to pay much attention to the label because that is not what is in it.
    What is?
    You are never told.
  10. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    While details are secret, is it safe to assume the pre-heating implies a high viscosity oil? I mean, just driving my car, a 1.6L engine with 20W50, my oil pressure is almost pegged at the 65 psi limit when the car is cold and oil is new, and when warmed up fluxuates normally with engine revs. If I was running 18k revs, I'd want a a high viscosity oil but it better be preheated or something's gonna blow up!
    Ken
  11. JCR
    JCR F1 World Champ
    10,770
    H-Town, Tejas
    Yes. Because while the POA basestock might be similar to what you can get over the counter, the number of ester bases number in the thousands of which only a much smaller number apply to IC engines and some of those can be expensive. The additive package in race oil, or lack thereof is completely inappropriate on regular street driven cars.
    The answer to the question "what's in formula 1 oil?" is most likely only known to the oil company's reseach chemists and the engine and transmission designers/engineers.
  12. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Cosworth is laying claim to a most powerful version of the new V-8 for F-1, With the new motor came anticipated problems. The biggest problems were from additional pressure on the pneumatic valve return system and higher pressures on cam faces and on finger followers. This and big end (rods) distortion of the bearing shell it was apparent choice of oil became critical to maintain oil film at 20,000rpm. Cosworth claims this weakness was shown with the spectacular engine failure of Nico Rosberg happened at Malaysia
    My guess is that heavier weight oils are in fact being used to insure the desired film strength and moreover an aggressive additive package to boost the film holding characteristics. Dang I wish I had some insite into what they are doing.
    One thing for sure, advances usually find their way into our everyday products years after the fact. Certainly motors of such short duration have completely different requirements and contain no detergents, nonetheless the aspects of the ultimate lubrication is a facsinating mental exercise.
  13. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,750
    Atlanta
    John!
    A Shell technician advised me that the base stock used in the Ferrari formula 1 engines is a group III base stock called, group HXIV or something to that effect. He further said that each track uses a different additive package due to different kinds of stresses at each track, but the same hydrocracked group III base stock is used. What got me was that he said the same base stock is used for Shell's Helix Ultra, and Rotella T synthetic which is available in the states.
  14. TopElement
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    It's possible, but relatively may not be too high compared to road cars.
    However, their motors are completely different. I recall from an engineering article mentioning that due to the tolerances of F1 engines, the oil needs to be pre-heated to get through some of the passages at startup.
  15. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Ya know, some of us may have our differences, but ya'll gotta admit this racing stuff is pretty incredible. 750 HP out of a 2.4 liter pegged at 19,000 RPM is just amazing. I thought it was amazing as a kid to know that a Cox .049 engine could get near 20K RPM, but a car engine?
    And no matter if they are running 0W or 70W oil, the fact they can hang together like they do is almost more amazing.
  16. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Complex and all good stuff, anyone with anything to add is welcome! I know someone is out there with some privey info. We promise we will hardly tell anybody. Keep diggin, lots of stuff going on.
  17. JCR
    JCR F1 World Champ
    10,770
    H-Town, Tejas
    It's a group III basestock but Shell's XHVI is a little different from other company's group III's. All the group III's are hydroprocessed and isomerized. Shell XHVI uses only the slackwax portion removed during solvent dewaxing of the crude then it goes through isomerization and hydroprocessing. It is supposed to rival PAOs in almost every performance category. http://www.patentstorm.us/patents/7067049-description.html
    They also supposedly tailor the viscosities to the track too.
  18. Ferraripilot
    May 10, 2006
    17,750
    Atlanta
    John!
    Different visocities for different tracks is precisely what I heard, or rather, it was suggested.
    I agree, Shell's group III is very different from anyone else's group III. I highly recommend Shell's Rotella T synthetic 5w-40 in any car with flat tappets. It's higher copper content and highly original base stock makes for a very beefy oil. If it is good enough for F1, it is good enough for me. It made my 911 track oil consumption go down by about half. Too soon for me to venture an opinion since using it in my 308 though.
  19. JCR
    JCR F1 World Champ
    10,770
    H-Town, Tejas
  20. Ferraripilot
    May 10, 2006
    17,750
    Atlanta
    John!
    My bad, I meant zinc. Been a while since I have really talked about this oil. I just use it.
  21. Ferraripilot
    May 10, 2006
    17,750
    Atlanta
    John!
    After reading that chart it must be calcium that does it. All kinds of information being spouted on oil sites. Great factual chart though.
