F1 Problem in self learning | FerrariChat
Discussion in '360/430' started by ahmeddmahe, Jan 19, 2024.
  1. ahmeddmahe
    ahmeddmahe Rookie
    May 3, 2023
    2
    F1 gts
    Hello,
    I have Maserati gran turismo 09 F1 gear box same as (Ferrari 430 ,599 gearbox )bought from an auction (actuator was stolen, tcu )
    car parked more than 2 year. i bought new tcu dealer programmed it with sd3, used actuator,so with sd3 self learning didn’t complete but can change gears from the device and hear acutator and hear the pump when open the door they told me to buy full kit because maybe bad (accumulator,pump…) I can buy it used and try to figure the problem but
    note :mechanic turned on the car from the starter motor under the car when he put the car on the (neutral from the device )
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,705
    Central NJ
    Dominick
    I see you PM'd me already .. I responded with a number to call me so that I can see if I can help
    Dominick
    fstbiker likes this.
  3. sammyf
    sammyf Formula Junior
    Aug 13, 2004
    258
    Northern California
    Will the engine start? Will it try to crank? Do you get a "Gearbox Unavailable" message on the dash?
