F1 pump motor screws | FerrariChat
Discussion in '360/430' started by HJZ360, Feb 13, 2022.
  1. HJZ360
    HJZ360 Karting
    Nov 27, 2017
    68
    Weslaco, Texas
    Harold John Zurlo
    360 F1 pump motor failed, what dimension screws hold motor to motor? I have to remove heads of both because they are frozen. I have also changed relay, pump resistance changes from almost open to 6.5 Ohms. Thanks!
  2. 24000rpm
    24000rpm F1 Rookie
    not understanding your question, what screw?
  3. HJZ360
    HJZ360 Karting
    Nov 27, 2017
    68
    Weslaco, Texas
    Harold John Zurlo
    Sorry, motor to pump. There are 4 - two hold pump case together, the other two hold motor to pump.
  4. 24000rpm
    24000rpm F1 Rookie
    ok? those 4 screws. What about them?
  5. HJZ360
    HJZ360 Karting
    Nov 27, 2017
    68
    Weslaco, Texas
    Harold John Zurlo
    The metric thread size and length
  6. 24000rpm
    24000rpm F1 Rookie
    you want to know the thread size and length of the 4 screws?
    Is that what you need? I can measure it for u
  7. HJZ360
    HJZ360 Karting
    Nov 27, 2017
    68
    Weslaco, Texas
    Harold John Zurlo
    Thanks, I removed the screw heads, matched at hardware store this afternoon.
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,917
    Central NJ
    Dominick
    For people searching in the future ..can you list Size and type etc
    That will help the community
    TIA
