F1 pump relay | FerrariChat
F1 pump relay
Discussion in '360/430' started by Whitby, Sep 26, 2023.
  1. Whitby
    Whitby Rookie
    Jul 12, 2015
    5
    Florida
    There used to be a source of solid state replacements for the factory F1 pump relay, but the links are all dead. Anyone know of an option to replace my aging relay, without simply buying a new one from Ferrari? I might end up doing that, just so I know the relay is not 20 years old, but this is one area where I think solid state is the way to go if it is an option. I drive my car, and track it occasionally, so I am not bothered by the non OEM status.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Scuding swiss on google will get you what you are after
    flash32 likes this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,954
    Central NJ
    Dominick
  4. Daryl Zernick
    Daryl Zernick Formula Junior
    Jul 7, 2020
    271
    South Bend, IN
    Daryl A. Zernick
  5. Daryl Zernick
    Jul 7, 2020
    271
    South Bend, IN
    Daryl A. Zernick
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,954
    Central NJ
    Dominick
    That is a mechanical .. it has a coil in it to pull a lever to contacts
    Solid state like scuding is all electronics
    I have mentioned before the biggest benefit of a solid state relay ( not a scuding..that is a different unit) is faster switching - you really don't need it here for this application
    Replacing them every few years with something like the one you posted is more than fine .. the only exception is if you are having issues with your F1 system that causes more cycling it is highly recommended to change once you fix the original problem
    Just a note - the pin setup on a solid state relay may be different and most likely will not have flyback protection
  7. tazandjan
    39,191
    If he has an older 360 (built before fall 2003), he only has a 30 amp relay.
    flash32 likes this.
  8. GogglesPisano
    GogglesPisano F1 Rookie
    3,218
    East Bay, California
    Joe
    AandSC likes this.
  9. collegeboy
    collegeboy Formula 3
    1,372
    Texas and Kaua’i
    Mikey
    For what it’s worth, I have a 2004 Challenge Stradale and I still have the old 30A relay in my car.
  10. tazandjan
    39,191
    Yup, early 2004 MY cars were built before the change was made in fall 2003. My Nov 2003 MY 04 575M has the 30-amp relay. The change on 575Ms was made at AN 52556 and it is probably pretty close to that for the V8s.
    A much better 30-amp relay is available through BMW. It is a Tyco V23134-B57-X266, BMW part number 61.36-8 366 646. I have had that same relay, not from BMW, for several years with no problems.
    GENUINE BMW 61 36 8 366 646 / 61368366646 - OEM BMW Parts – Online BMW Parts Store (bmwpartsfactory.com)
    Sj_engr likes this.
