F1 pump? | FerrariChat
F1 pump?
Discussion in '360/430' started by felo360, Dec 26, 2010.
  1. felo360
    felo360 Rookie
    Nov 2, 2010
    43
    Hi, how long does the Pump run after opening the driver door on a 360 2000 ?
  2. TALON30
    TALON30 Karting
    Jan 8, 2010
    171
    i have a 03 and i would guess about 5 sec.
  3. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    about 3-6 seconds, depending on how long the car was not operational
  4. sk8rpatty
    sk8rpatty Formula Junior
    Dec 13, 2010
    316
    So Cal
    Patty H.
    Just timed it, on my 2000 360....10 sec. Yes, I'm bored.
  5. sk8rpatty
    Dec 13, 2010
    316
    So Cal
    Patty H.
    #6 sk8rpatty, Dec 27, 2010
    I just timed it to help out the OP. Wasn't looking for someone to tell me there is a problem. Yikes, I certainly hope that's not the case...
  6. sk8rpatty
    Dec 13, 2010
    316
    So Cal
    Patty H.
    Hi Juri, I didn't mean to sound ungrateful. Thanks for all the links to the other threads!! It's good information to have IF I do indeed have a problem. I actually read the pump replacement thread before when I was having the 'transmission fail" light problem caused by a low battery. I came to this site to seach for information. The car has been running fine ever since I got the fault to clear, so I'm assuming everything is okay. Everyone was so nice I've decided to stick around in case I have any other dumb questions related to the cars.
    As an engineer, I found it an interesting read, however I lack the experience and the tools to do anything like that myself. I was happy I was able to hook up the battery tenders myself. haha
    Cheers,
    Patty
  7. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    No problem Patty.
    I also hope that your F1 pump will continue to function normally.
    Dont hesistate to ask if there will be any problems...
    Cheers.
    Juri.
  8. sk8rpatty
    Dec 13, 2010
    316
    So Cal
    Patty H.
    Thanks Juri!! By the way, I love your signature line.
  9. Challengehauler
    Challengehauler Formula 3
    Jul 28, 2008
    1,315
    NE Connecticut
    DB
    Replace the relay and see if that shortens prime time. The relay craps out and the pump will run while the car is parked burning out the motor.
  10. BLAMPEE
    BLAMPEE Man Card Status: Never Issued
    #11 BLAMPEE, Dec 27, 2010
    FoS recently installed a 360 F1 pump (and new relay) into my 355 two months ago to replace my failing original. The old one used to run for a minimum of 8-12 seconds while the F1 indicator light did it's thing flashing not allowing me to take the car out of gear to start it.
    Now, it runs for about 1-3 seconds--it is blazingly fast and I can literally take the car out of gear almost immediately upon turning the key. :D
  11. sk8rpatty
    Dec 13, 2010
    316
    So Cal
    Patty H.
    Much easier to replace the relay than the pump. Sounds like it's worth a try.
    However the time of the pump running still seems to be a function of the time since I've last opened the door, like one would expect...
    What happened to the OP??
  12. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    #13 Juri, Dec 27, 2010
    Well, here is what I can tell about the relay - the old-type relays are not reliable, as I described before:
    http://www.ferrarichat.com/forum/showthread.php?t=268458&highlight=juri
    Therefore, my suggestion is to replace the old relay with the latest model (grey or orange in color; search FerrariAds section of this forum).
    Also, to prolong the life of your pump and improve it's operation, you may consider installing the F1 puimp radiator kit:
    http://www.ricambiamerica.com/product_info.php?products_id=343620
    Cheers.
  13. sk8rpatty
    Dec 13, 2010
    316
    So Cal
    Patty H.
    Is this the relay part number you would suggest? Tyco V23134-B57-X203
  14. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    I recommend using V23134-B57-X152 or V23134-B57-X266, which is even better.
  15. sk8rpatty
    Dec 13, 2010
    316
    So Cal
    Patty H.
  16. nchhotu
    nchhotu Formula Junior
    316
    Roseville, Ca.
    Nick
    Hi juri I would like to upgrade my 2007 F430 F 1 pump.
  17. maicholferrari360modena
    Jun 22, 2024
    17
    ciao una domanda , radiatore pompa f1
    sì puo' installare anche su ferrari 360 modena ?
