F1 shifting & gas pedal | FerrariChat
Discussion in '360/430' started by chocodip, Nov 1, 2007.
  1. chocodip
    chocodip Karting
    Nov 15, 2004
    56
    Sorry guys, i got a question when you upshift or downshift the gear do you step on the gas pedal? or it's better to lift off (better for the gearbox).......as i just got it a day so i wonder which way is best to keep the best condition out of it.
    thks alot
  2. Camdon53
    Camdon53 Formula Junior
    Jul 18, 2006
    507
    Texas, USA
    Jim
    This is covered in some detail by the owner's manual. Under most circumstances you simply keep the throttle steady for shifting.
  3. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,166
    Wash DC area
    Robert
    I never lift on the upshift and please read the manual, it has some great advice for shifting. I always run the car in "sport" mode as this provides less slippage of the clutch. i have also found the sweet spot for my car is right at 5500rpm to 6000 rpm less "jerk" and I have moderate throttle input on this shift. You will also find that the car will shift quicker depending on the throttle input, at wot "wide open throttle" the car shifts like a cannon, very quick!!
    When down shifting I am always off the throttle as I am usually coming to a stop. On that note, I also allow the car to downshift from 2nd to 1st at a stop. Also, its ok to leave the car in gear while waiting at a light. This is also covered in the manual.
    Happy reading and congrats on the new car!!!! Remember its not official until we see pics!!!!
    Robert
  4. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    Also covered in several threads accessed through the search function
  5. Gerald Pieroni
    Sep 8, 2007
    17
    Ca
    Hi Everyone!
    This is my first post. I received my "07 430 F1 three weeks ago. It's yellow with black leather interior/yellow stitching. I'm confused regarding downshifting and the gas pedal. My owners manual states that you should keep the gas pedal engaged(on the throttle) which doesn't make sense. Is this a typo? Do you actively downshift or let the car downshift by itself? Thanks for the input.
  6. chocodip
    chocodip Karting
    Nov 15, 2004
    56
    #6 chocodip, Nov 1, 2007
    hi guys,
    here's a pic.....recently the weather in HK aint that great......hope i can shoot some nice ones this wkN. Got my car window tinted, film protection on front and side air intake venders. As well changed the white light bulb and 6k xenon (will take pics tonite).
    2007 Nero, CCB , polished wheel, rear parking sensor
    p.s. I just notice the deck is able to use BT with my phone......anyone here change their deck?
  7. CAPRISTO EGOISTE
    Oct 25, 2007
    99
    Istanbul
    CAPRISTO EGOISTE
    Well it depends on the mode you are drivin' the car. But I prefer not to change gear too harshly and step on the pedal dependable on your speed and the gear. When downshiftin' do not kick the pedal . :)
    Moreover check the owner's manuel for more info!!
  8. J2J
    J2J Formula Junior
    Jan 11, 2008
    271
    I'm a 430 F1 newbie as well....aside from when you are really pushing the car...what way seems to be the best for the tranny/clutch to start from a dead start? Do you give it steady gas or are you progressively giving more as the clutch engages?
  9. The Ape
    The Ape Formula 3
    Feb 28, 2007
    1,793
    Los Angeles
    Ape
    Drive the car everyday and drive it hard. You will find the sweet spots of your tranny rather quickly by just driving it a LOT.
  10. hamdog
    hamdog Formula Junior
    Mar 21, 2005
    729
    Northern VA
    Hamdog
    Easy answer would be steady gas. The manual will tell you not to modulate. I found that it can vary depending on if the car is cold or at operating temp. The clutch seems to engage much slower when its cold. Just keep playing with it till you find the balance.
