F1 shifting problems | FerrariChat
Discussion in '360/430' started by jzcar, May 1, 2014.
  1. jzcar
    jzcar Karting
    Mar 23, 2012
    157
    N Florida
    I had my car detailed the other day, including the engine compartment. When I drove it today for the first time since, the car hesitates, slips, then jumps a bit as it begins from a standing start in first gear. Car shifts perfectly through all other gears, up and down. Is this just a coincidence that the problem started after the detail job? Or could it be that the problem was caused by some of the work that was done in the engine compartment...something got hit or bumped, etc. Has anyone experienced a problem like this?
  2. Chiaroman
    Chiaroman Formula 3
    1,687
    New Jersey
    Mileage in...mileage out...
    Did you see Ferris Bueller's Day Off???
  3. up4speed
    up4speed F1 Rookie
    3,693
    Long Island, NY
    Chris
    I was thinking the same thing
  4. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    As above!
    I'm sure many an owner has noticed an extra little issue after a detailing and Youtube/Google have many Ferrari accidents with a "detailer" found to have been behind the wheel (just taking it for a spin to dry it off "naturally" before applying polish & wax).
    Never leave your car with someone you don't trust to look after it correctly.
  5. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    ^^ As above, detailing the car will not cause this. An ignorant driver will though.
    If I paid for a detail I would stay and watch so I can do it myself next time.
  6. jzcar
    jzcar Karting
    Mar 23, 2012
    157
    N Florida
    Sorry for not addressing the "mileage in, mileage out" issue at the outset, but I never dreamed an owner would allow a detail shop to drive their car. Never even thought to touch that base. The detail shop was mobile. I had the keys in my pocket at all time. They never even started the car. I mowed the yard while they detailed.
    While I thought from the beginning that there was a very remote chance that having the engine detailed could have amounted to shifting problems, I thought it worth the chance to at least inquire about that possibility.
  7. JTR
    JTR Formula 3
    Apr 26, 2005
    1,502
    in a house
    Please explain how an ignorant driver ( do you mean the detailer or the owner?) could cause this problem with an F1???
    I'm new myself to F1, but I'd agree that its likely a wiring connection either wet or now loose.
  8. Skidkid
    Skidkid F1 Veteran
    9,538
    Campbell, CA
    John Zornes
    Many of the connectors in the engine bay are not as water tight as one might hope. Get some contact cleaner, disconnect and spray them, then reconnect. Your problem should go away.
  9. jzcar
    jzcar Karting
    Mar 23, 2012
    157
    N Florida
    Thank you, thank you, thank you.
    This is what I've been looking for. I came here looking for honest solutions to an honest problem and all I got was quotes from Ferris Bueller.
  10. vrsurgeon
    vrsurgeon F1 World Champ
    16,543
    Charleston, SC
    Curt
    Clutch sensors are around the oil filler neck on the top of the engine where you check the oil at its base IIRC. I'd be thinking the clutch position sensor connector might have gotten wet, varying the normal resistance.
  11. up4speed
    up4speed F1 Rookie
    3,693
    Long Island, NY
    Chris
    That's correct, it's accessible from the passenger side.
  12. jzcar
    jzcar Karting
    Mar 23, 2012
    157
    N Florida
    you guys are smart. that's why I asked. I stand amazed at how much you can learn from this website. I've only been a Ferrari owner for two years and have a lot to learn. But because the car shifted so well prior to the detail job, I had a hunch that could have been the problem.
  13. OUMick
    OUMick Formula 3
    Apr 26, 2014
    1,090
    Myrtle Beach, SC
    There is electrical contact dryer you can buy at the auto parts store. In my business with pool heater, we coat the circuit boards with electrical contact protector. It keeps any moisture from coming in contact with the electrical.
