360 - F1 stuck in N | FerrariChat
360 F1 stuck in N
Discussion in '360/430' started by Richard A Bowen, Aug 2, 2020.
  1. Richard A Bowen
    Nov 6, 2018
    11
    Reno, NV
    RICHARD BOWEN
    Drove the '03 360 today 70 miles, no issues. Pulled into neighborhood & stopped to put the top up.
    Couldn't get it in gear. Tried "auto", same. No reverse also. During the tow back to my house, I could get it in gear. Stopped to unhook, went to N again. Began tow, strop broke and I got it into 1st and passed the tow vehicle and got it in the garage. Once stopped no gear selection.
    Any ideas?
    Thanks in advance,
    Richard
    Car bought with 8K miles and I've put 4K on it. Serviced on schedule.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,924
    Central NJ
    Dominick
    Let's start with a few questions
    Any error lights on dash
    When you open door do you hear pump ...how does it sounds ..how long does it stay on
    Anything done to car in the last week or so
    Any leaks or funny smells
    Do you have a code reader
    Sent from my moto g(7) using Tapatalk
  3. Richard A Bowen
    Nov 6, 2018
    11
    Reno, NV
    RICHARD BOWEN
    Thanks! Nothing on dash. All hatches secured. Pump worked ok & working now when parked after a time. No smells. Reservoir full. No code reader. 377,miles to dealer, thankfully I have a transporter.
  4. tmvatlanta
    tmvatlanta Formula Junior
    Mar 26, 2017
    389
    Covington GA
    Tam V.
    Do the brake lights work? F1 tranny will not engage any gear if the car doesn’t know you have your foot on the brake pedal.
    My guess is: the fuse for brake lights blew. It happened to me once.
    sparetireless and flash32 like this.
  5. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Clutch could be worn
    E60 M5 likes this.
  6. Richard A Bowen
    Nov 6, 2018
    11
    Reno, NV
    RICHARD BOWEN
    Thanks! Will check tomorrow and advise. I did just put top up, maybe that "surge" blew a fuse.
  7. Richard A Bowen
    Nov 6, 2018
    11
    Reno, NV
    RICHARD BOWEN
    Hoping not the clutch. $$$$
  8. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,792
    western hemisphere
    I bet it's something simple.
    Skidkid likes this.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,924
    Central NJ
    Dominick
    After hearing your symptoms and the answers...I would agree with above post (twvAtlanta)about brake switch .. it is something that has come up before .. check it out and let us know
  10. irix
    irix Karting
    Aug 28, 2015
    51
    Germany
    J.B
    Breakswitch on Break pedal
    Tail lights (check the bulbs)
    Regards,
    Joerg
    APA#1 likes this.
  11. LP360
    LP360 Karting
    Jun 12, 2016
    174
    Lee
    Had this happen to me, soon as I selected N it wouldn't go into any gear.
  12. Hypek9
    Hypek9 Karting
    Apr 9, 2012
    162
    Australia
    Most likely brake switch or F1 relay
  13. brookliner7
    brookliner7 Formula Junior
    843
    San Antonio, TX
    Hans
    #13 brookliner7, Aug 3, 2020
    I don't have a spider, but I assume if the sensor doesn't recognize the top is closed it won't let you go into gear. Brakes are the same thing if the lights out or the switch sensor on the pedal you can't go into gear and there's no warning light.
    Most other things that leave you stuck in neutral will give you a dash warning light such as door open, frunk open, or the engine lid open.
  14. ttforcefed
    ttforcefed F1 World Champ
    19,256
    is ur front hood open? that will cause an N.
  15. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Same thing happen to me bad brake light switch. You can buy one from Maserati 25.00 same part number as Ferrari one same box . Hard to believe such a small part will disable a your 360.
  16. Richard A Bowen
    Nov 6, 2018
    11
    Reno, NV
    RICHARD BOWEN
    TMVAtlanta nailed it! Blown 10 amp brake light fuse. Cycled top, all good. Just to be safe, when I raise/lower top I will set P brake and not have my foot off brake pedal. Dunno why fuse blew.
    There IS a 10 amp fuse in the tool kit, added a few more!
    Thanks for everyone's input.
  17. Richard A Bowen
    Nov 6, 2018
    11
    Reno, NV
    RICHARD BOWEN
    Determined why brake light fuse was blowing. Short in 3rd brake light switch under engine deck lid.
