F1 system oil | FerrariChat
F1 system oil
Discussion in '360/430' started by Ingpr, Nov 23, 2009.
  1. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    What kind of oil is used on the F1 pump system for the F360?
    Which is a good brand of oil?
  2. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    Dexron III or better.
  3. Rifledriver
    37,122
    Not true.
    Many use Tutela CS Speed hydraulic oil.
    You need to stay with what was intended for the car in question. Look in the owners manual for the correct type. It was included with the car for that reason among others.
  4. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    #4 Skidkid, Nov 24, 2009
    I stand corrected. I didn't know that they changed fluid and owners manuals in the run of 360's.
    EDIT: -----
    When I did a search on the Tutela I found this:
    TECHNICAL DATA:
    ATF Dexron III
    Mercon
    ZF TE-ML 11/14 Level
    BUT, it is fully synthetic so there is a difference that may make mixing a bad idea (depends on formulation).
    I suspect that this synthetic is better than standard ATF. It should have better cold temp characteristics so cold shifting should be better. It is probably more heat tolerant too and we all know it can get very hot back there.
  5. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Thanks guys!
    The people from Redline recomends their product; D4ATF
    What do you think?
  6. Rifledriver
    37,122
    It is an exellent product and what we use in the ATF cars.
