355 - F1 system stays primed a long time ?? | FerrariChat
355 F1 system stays primed a long time ??
Discussion in '348/355' started by Skippr1999, Nov 25, 2019.
  1. Skippr1999
    Skippr1999 F1 Rookie
    4,520
    This is the opposite of what most people post with pressurization issues.
    I’ve recently noticed my F1 system is staying primed or pressurized for extended periods of time. The fluid is sucked out of the canister into the system and doesn’t return to the canister for days. I’ll turn the key and there are no F1 lights flashing (priming). I can change all the gears fine.
    In the past, the fluid returned to the canister over night. There are no drive-ability issues, I’m just wondering why the system is staying primed for so long.
  2. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    556
    Tempe
    Jon
    You should hook the car up to a SD2 and watch the pressure readings to see if the pressure is decreasing at each shift (up or down). Car can be sitting still with key on.
    At the next service interval, you may want the technician to run a bleed cycle on the f1 actuator.
  3. Skippr1999
    4,520
    Thanks John,
