F1 transmission | FerrariChat
F1 transmission
Discussion in '458 Italia/488/F8' started by hkoh77, Apr 28, 2010.
  1. hkoh77
    hkoh77 Karting
    Nov 8, 2007
    173
    Seoul, Korea
    Hi guys. I finally placed a deposit on a 458. I'm sure this question might have been covered somewhere on this board, but I can't seem to find it through the search. All of my sportscars so far have been manual. The 458 I placed an order for only comes in the F1 transmission, so the first question that came to my mind was, how do you shift an F1 transmission? Do you lift your foot off the accelerator in between shifts, just like a manual? or do you just keep your foot pressed and just shift? Once again, I apologize if this question is a repost. Thanks.
  2. TheMayor
    106,081
    Vegas baby
    #2 TheMayor, Apr 28, 2010
    The 458 gearbox is not really like the past Ferrari/Maserati F-1's. However, it works pretty much the same way.
    All you do it pull the handles. You keep your foot on the throttle. Right is for upshifting, left is for downshifting. The engine management software does all the work as far as matching the engine to the gearbox. There's a gear number indicator in the Tach. It's very simple and takes only a few minutes to get used to. I've been driving them since 2002 and I like them.
    They also have an "auto" mode for valet's or someone who doesn't want to do their own shifting. Personally, I never use it but I can see for some how it might be useful -- especially if you are just stuck in traffic.
  3. Lesia44
    Lesia44 F1 World Champ
    17,890
    As bdelp says, very simple and takes only a few minutes to get used to. Only problem I had when I first drove one (a 355 F1 a long time ago) was for the first five junctions and roundabouts I slammed on the breaks as my left foot automatically depressed the clutch. Of course, there is no clutch so I ended up stamping the brake to the floor. The sudden stop comes a quite a surprise when you're not expecting it and I was really lucky there was no-one behind me.
    Love paddles.
  4. Forexpreneur
    Forexpreneur Formula Junior
    May 11, 2009
    638
    Portland, OR
    Alexander Everhart
    As far as the other two posts, they are right on. On the newer F1 tranny's you don't have to worry about lifting the throttle.
    The big thing to remember, there is still a clutch. Granted not one you have to press, but there is a clutch. So when you come to a stop put it in neutral (flip both the left and right paddles at the same time) if you have to sit more than a second or two. This is incredibly important in stop and go traffic like Los Angeles and other big cities can experience. If you don't put it in neutral you will burn the clutch fairly quickly. I've heard as early as 1,500 miles. Not sure about that one but a clutch can go much quicker in an F1 than a manual car if one doesn't remember about neutral.
    I hope that helps. :)
  5. hkoh77
    hkoh77 Karting
    Nov 8, 2007
    173
    Seoul, Korea
    Thanks guys. Much appreciated. Now all I have to do is wait about a year. =(
  6. stereotaipei
    stereotaipei Formula Junior
    Jan 27, 2010
    256
    Taiwan + Europe
    Are you sure that it is still the case with a dual clutch car? I never put on neutral on my Audi S4...
  7. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    It's not an F1, it's a dual clutch. Different systems.
    The clutch in the DCT is a wet clutch, good for the life of the gearbox.
    You don't have to put it in neutral at a light or in traffic.
    I'd probably ask a LOT of questions at the dealer before I spent $300,000.
